Sat, Jan 25, 3:03 PM CST
Subject: Animated Smoke
arrow1 ( ) posted Sat, 22 December 2012 at 2:42 PM · edited Sat, 25 January 2025 at 3:02 PM
Online Now!
Is it possible to make animated smoke for example coming from the stack of a coal burning ship in Vue 11 Infinite? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Mazak ( ) posted Sat, 22 December 2012 at 2:59 PM · edited Sat, 22 December 2012 at 3:00 PM
Attached Link: https://www.youtube.com/watch?v=4FJD7tvs6BM
Yes , an smoke example is included in Vue11.
Mazak
Google+ Bodo Nittel
Mazak ( ) posted Sat, 22 December 2012 at 3:01 PM
Attached Link: https://www.youtube.com/watch?NR=1&v=uSyDrnIE7LQ
and one example from Vladimir chopine:
Mazak
Google+ Bodo Nittel
arrow1 ( ) posted Sat, 22 December 2012 at 3:13 PM
Online Now!
Many thanks.Is there a tutorial available on this? Cheers
Mazak ( ) posted Sat, 22 December 2012 at 3:21 PM · edited Sat, 22 December 2012 at 3:22 PM
Attached Link: http://www.geekatplay.com/dv11.php
geekatplay has some basic vue11 tutorials.
http://www.geekatplay.com/vue.php
Mazak
Google+ Bodo Nittel
arrow1 ( ) posted Tue, 25 December 2012 at 1:21 AM
Online Now!
When you animate smoke with volumetric material on a sphere, do you distort the sphere to change the direction of the smoke or do you add more spheres? What I am trying to do is add animated smoke continually coming out of funnels on various ships on the horizon! Any help appreciated. Cheers
Mazak ( ) posted Tue, 25 December 2012 at 3:12 AM
Place in front of your particle system an ventilator activate influence particles (see example), and the particles blown in direction you like.
Mazak
Google+ Bodo Nittel
Mazak ( ) posted Tue, 25 December 2012 at 4:47 AM
Attached Link: http://www.impworks.co.uk/2012/11/vue-11-particle-effectors/
Particle effectors in Vue11 a quick reference by member impish:
Mazak
Google+ Bodo Nittel
arrow1 ( ) posted Tue, 25 December 2012 at 4:54 PM
Online Now!
Are the blue balls separate spheres? They do not seem to show up in the browser!
Mazak ( ) posted Tue, 25 December 2012 at 5:06 PM · edited Tue, 25 December 2012 at 5:08 PM
Yes the smoke is made from particle spheres. The new particle system in Vue11.
Here a small animation and the scene file for you.
The Video: https://www.youtube.com/watch?v=gl2J8-AZ2tI
The Scene file: https://dl.dropbox.com/u/84286786/Smoketest.vue
Mazak
Google+ Bodo Nittel
arrow1 ( ) posted Wed, 26 December 2012 at 12:03 AM
Online Now!
Mazak, Many thanks for your help. I am gradually starting to work this out thanks to your link. I have hopefully only one last question: I am animating the cylinder as a ships funnel moving right to left or along the x axis but the smoke does not move with it. Do I link something together in the animation palette? Cheers
Mazak ( ) posted Wed, 26 December 2012 at 4:13 AM · edited Wed, 26 December 2012 at 4:18 AM
*(click the picture for large view)*
Ok, do this.
With shift select the cylinder and the plane (both selected) right click and select group object.
Delete the ventilator (or move it away).
Move the group and create a key-frame animation. Play the animation, the smoke follow now the cylinder.
Mazak
Google+ Bodo Nittel
arrow1 ( ) posted Fri, 28 December 2012 at 12:14 AM
Online Now!
Great.That worked! If I use the funnel of  model ship. Do I still need to have the cylinder as well? If so how can I parent the cylinder to the funnel of the ship? Cheers
Mazak ( ) posted Fri, 28 December 2012 at 2:27 AM
You need the plane only. Group it to your ship and move the plane to the place you like.
Mazak
Google+ Bodo Nittel
arrow1 ( ) posted Fri, 28 December 2012 at 4:53 PM
Online Now!
One problem I am finding is that I have to destroy my animation of the ship (Done in Poser) in order to group the plane! Also trying to re animate my ship is a problem as every move I make the program keeps wanting to re compute the physics. It takes forever to finish. Smoke just goes straight up not moving to the stern as my boat moves .Cheers
Mazak ( ) posted Fri, 28 December 2012 at 5:44 PM
Convert the Poser object to an Vue object and bake the particle animation should solve the problem easy.
Mazak
Google+ Bodo Nittel
arrow1 ( ) posted Fri, 28 December 2012 at 6:06 PM
Online Now!
The Poser object has already been converted to a Vue object and saved! I will bake the particle animation. Cheers
arrow1 ( ) posted Fri, 28 December 2012 at 7:07 PM
Online Now!
Still having destroying my Poser animation problems.Even after baking plane to polygons.Cheers
arrow1 ( ) posted Fri, 28 December 2012 at 7:08 PM
Online Now!
Also I get this!
Mazak ( ) posted Sat, 29 December 2012 at 3:53 AM
Why did you import the ship with poser an animation?
Mazak
Google+ Bodo Nittel
Mazak ( ) posted Sat, 29 December 2012 at 4:39 AM
I did this quick test. I imported one of my ships from Poser and grouped it with the smoke plane. Then I animated the group and baked the planes particles. Very easy.
I think you did something wrong on Poser import. I can not reproduce your problems.
Mazak
Google+ Bodo Nittel
Mazak ( ) posted Sat, 29 December 2012 at 4:55 AM
Mazak
Google+ Bodo Nittel
arrow1 ( ) posted Sat, 29 December 2012 at 4:45 PM
Online Now!
The reason I animated in Poser was I wanted a rock and roll motion with rough seas. However I will re import the ship and animate it in Vue. Many thanks for your patience.Cheers
