Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 22 4:30 pm)
i often use poser whilst not connected to the web, so i cant see that being the issue, has the pc you are using got adobe air installed or if installed ,updated?
OS: Windows7 64-bit Processor Intel(R) Core(TM)
i5-2430M CPU @ 2.40GHz, 2401 Mhz, 2 Core(s), 4 Logical
Processor(s) 6GB Ram
Poser: Poser Pro 2012 SR3.1 ...Poser 8.........Poser5 on a bad
day........
Daz Studio Pro 4.5 64bit
Carrara beta 8.5
Modelling: Silo/Hexagon/Groboto V3
Image Editing: PSP V9/Irfanview
Movie Editing. Cyberlink power director/Windows live movie
maker
"I live in an unfinished , poorly lit box, but we call it home"
My freestuff
link via my artist page
edit, rdna forums has an answer that may work...You need to adjust your firewall settings to allow the library code to access the internet or at least localhost (aka 127.0.0.1)
and
If you are not connected to the internet, you will always see the fault message, as the library ALWAYS tries to contact Content Paradise (if anyone knows how to disable this I'd apreciate it). Usually after hitting OK, as long as your library manager has permission to access the local host (127.0.0.0) all will work fine.
day........
Carrara beta 8.5
maker
My freestuff
I've had it happen using PP2010 on an airplane w/o a connection, obviously. IIRC if you click on the 'OK' button in the Library pane when I get the error it will proceed and function normally... I just tried it with my network card disabled and it is indeed the case. This is the 32-bit PP2010 with the internal library...
"Oh - the manual says that? I have never read the manual - this must be why."Quote - > Quote - hey jimmyjohn ... if you have no connection, how are U posting here? :huh:
Well spotted!
From a neighbour's PC, Sherlock. ;-)
:biggrin:
BTW - I'm glad everything is back to Norma ... BTW#2 ... Who's Norma?
cheers,
dr geep ... :o]
edited 10/5/2019
I was tempted to ask the same question Geep, but without bringing my innermost fears of a man morphed into a phone line to life, I decided to presume by his phone or something similar, but i am intrigued who norma is and why everything has gone back to her :)
day........
Carrara beta 8.5
maker
My freestuff
I am connected to the internet and I have the same problem. I am using Poser Pro2012. The Library window comes up with that same exact message. I have all the updated installed. It was working fine all day until a couple of hours ago. Now I can't do a thing with it. Please help before I uninstall it. Thanks :(
Hello!
I m running PP 2010
When I open POSER, the library window doesn't show, instead, I get the following error message:
FAULT DETECTED - OP: appConfig
I m on holydays in a place where I dont have an internet connection.Is there a relation?
Please, help!
And happy holydays to you all.
