Mon, Feb 17, 2:43 PM CST
Forum Moderators: RedPhantom
Subject: Monitor Calibration Question...
WandW ( ) posted Fri, 28 December 2012 at 3:17 PM · edited Fri, 14 February 2025 at 3:28 AM
Somehow my desktop colour settings got reset, perhaps as a result of a driver update. I recalibrated my monitors using these images...
http://www.lagom.nl/lcd-test/
All looks good on the test images, but I happened to load up a render I did a couple of weeks back and the black horse's torso (especially the backside) is practically a silhouette on both monitors; does it look that way to others?
Thanx for any feedback... 😄
LaurieA ( ) posted Fri, 28 December 2012 at 3:21 PM · edited Fri, 28 December 2012 at 3:22 PM
Hmmm..no....not the same on mine. I can see detail in the black hair the whole way across. In the mane and tail too. I can even see detail in the hair on the far back leg that's in shadow. I have two Samsung monitors...just recently calibrated too.
mysticeagle ( ) posted Fri, 28 December 2012 at 3:21 PM
nope WandW, it looks like a dark grey horse to me..not actually black black
OS: Windows7 64-bit Processor Intel(R) Core(TM) i5-2430M CPU @ 2.40GHz, 2401 Mhz, 2 Core(s), 4 Logical Processor(s)  6GB Ram
Poser: Poser Pro 2012 SR3.1 ...Poser 8.........Poser5 on a bad day........
Daz Studio Pro 4.5  64bit
Carrara beta 8.5
Modelling: Silo/Hexagon/Groboto V3
Image Editing: PSP V9/Irfanview
Movie Editing. Cyberlink power director/Windows live movie maker
"I live in an unfinished , poorly lit box, but we call it home"
My freestuff
 link via my artist page
randym77 ( ) posted Fri, 28 December 2012 at 3:39 PM
Online Now!
Looks great to me.  Well, aside from the fact that it's levitating.  ;-)
CaptainMARC ( ) posted Fri, 28 December 2012 at 3:47 PM
The horse looks fine to me.
Now, there's some very clever people here who know a lot more about this kind of stuff, but I've been well served by the Monitor Calibration Wizard...
http://www.hex2bit.com/products/product_mcw.asp
It's freeware and you can easily undo any changes you make if you don't like it, and you can even have different profiles, for example for daylight and nighttime.
vitachick ( ) posted Fri, 28 December 2012 at 3:49 PM
Perfect to me.. Also Samsung monitor
Win10  Poser 2014/Poser 11 Daz3D
markschum ( ) posted Fri, 28 December 2012 at 4:17 PM
looks good to me , some odd streaks in the mane but thats in a very closeup view.
WandW ( ) posted Fri, 28 December 2012 at 5:15 PM
Thanx for the input, all! 😄
For some reason Windows will no longer load the monitor profiles I generated in PSP, giving an 'incorrect paramater' error when i try to reload them.  Recreating them didn't help either so I used the Windows monitor calibration utility.  All looks good now image-wise, although the calibration chart from the website shows I can't distinguish black levels lower than 6, but my renders look like they should... 😄
caisson ( ) posted Fri, 28 December 2012 at 6:41 PM
Worth having a look at the histogram for the render in an image editor - the dark areas aren't clipping, but there is a lack of contrast. The highlights are barely above mid-gray. Such a compressed tonal range makes the image appear much darker and less detailed than it actually is.
Not approved by Scarfolk Council. For more information please reread. Or visit my local shop.
hornet3d ( ) posted Sat, 29 December 2012 at 6:55 AM · edited Sat, 29 December 2012 at 6:56 AM
Horse looks fine to me, again on Samsung monitors.  I calibraite using a Spyder 3.
aRtBee ( ) posted Sat, 29 December 2012 at 7:19 AM
looks fine, blackish grey with all details.
Dual samsung with regular Spider calibration over here.
WandW ( ) posted Sat, 29 December 2012 at 7:21 AM
I'd expect the tonal range to be small, caisson, as it is the shady side of a black horse.  All is well again on my desktop, tho'   😄
caisson ( ) posted Sat, 29 December 2012 at 2:10 PM
Sorry - what I was trying to say was that the histogram measures data irrespective of how an image appears on any monitor. I have a calibrated monitor (i1 device) and to me the render appeared underexposed. The histogram (attached) confirms it - sure it's a black horse, but it has a white blaze and socks, with the strongest light source coming from slightly behind so I would expect the edge highlights there to be approaching white.
Don't mean to come across as pedantic, but I know a little about correct exposure, and a low-key image should still have a full tonal range or it'll look technically wrong ...
Netherworks ( ) posted Sat, 29 December 2012 at 2:20 PM · edited Sat, 29 December 2012 at 2:21 PM
Looks fine to me.  I can see variation in the black.
I use the following test pattern that I save to the HD: http://www.photofriday.com/calibrate.php
I use Powerstrip to get the changes to stick because my monitor controls only go so far (Acer): http://entechtaiwan.com/util/ps.shtm
Powerstrip can also adjust the temperature if your monitor is off a bit there too.  It can do much more than that too.  It is around $30 and worth every penny.  Running Windows 8 here.
MikeMoss ( ) posted Sat, 29 December 2012 at 3:06 PM
Hi
I'm in the process of setting up my new monitor today.
Getting it synced between Photoshop and Indesign I was having some problems.
New computer and monitor.
I finally think I have it about set, and my desktop looks right.
I can see detail in the horse all over even in the thigh area, but it is dark, it also looks like it's supposed to look that way not like its under exposed if you get what I mean.
It doesn't look like an image that should be lighter and is too dark, if that makes any sense.  You can see by the shadow that it's back lighted and that's how it looks.
Mike
If you shoot a mime, do you need a silencer?
