Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 3:46 am)
nope WandW, it looks like a dark grey horse to me..not actually black black
Â
OS: Windows7 64-bit Processor Intel(R) Core(TM)
i5-2430M CPU @ 2.40GHz, 2401 Mhz, 2 Core(s), 4 Logical
Processor(s)Â 6GB Ram
Poser: Poser Pro 2012 SR3.1 ...Poser 8.........Poser5 on a bad
day........
Daz Studio Pro 4.5Â 64bit
Carrara beta 8.5
Modelling: Silo/Hexagon/Groboto V3
Image Editing: PSP V9/Irfanview
Movie Editing. Cyberlink power director/Windows live movie
maker
"I live in an unfinished , poorly lit box, but we call it home"
My freestuff  Â
 link via my artist page
The horse looks fine to me.
Now, there's some very clever people here who know a lot more about this kind of stuff, but I've been well served by the Monitor Calibration Wizard...
http://www.hex2bit.com/products/product_mcw.asp
It's freeware and you can easily undo any changes you make if you don't like it, and you can even have different profiles, for example for daylight and nighttime.
Thanx for the input, all! Â
For some reason Windows will no longer load the monitor profiles I generated in PSP, giving an 'incorrect paramater' error when i try to reload them. Recreating them didn't help either so I used the Windows monitor calibration utility. All looks good now image-wise, although the calibration chart from the website shows I can't distinguish black levels lower than 6, but my renders look like they should...
"Oh - the manual says that? I have never read the manual - this must be why."Worth having a look at the histogram for the render in an image editor - the dark areas aren't clipping, but there is a lack of contrast. The highlights are barely above mid-gray. Such a compressed tonal range makes the image appear much darker and less detailed than it actually is.
Not approved by Scarfolk Council. For more information please reread. Or visit my local shop.
Horse looks fine to me, again on Samsung monitors. Â I calibraite using a Spyder 3.
Â
Â
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU .  The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
looks fine, blackish grey with all details.
Dual samsung with regular Spider calibration over here.
- - - - -Â
I'd expect the tonal range to be small, caisson, as it is the shady side of a black horse. All is well again on my desktop, tho' Â
"Oh - the manual says that? I have never read the manual - this must be why."Don't mean to come across as pedantic, but I know a little about correct exposure, and a low-key image should still have a full tonal range or it'll look technically wrong ...
Looks fine to me. I can see variation in the black.
I use the following test pattern that I save to the HD: http://www.photofriday.com/calibrate.php
I use Powerstrip to get the changes to stick because my monitor controls only go so far (Acer): http://entechtaiwan.com/util/ps.shtm
Powerstrip can also adjust the temperature if your monitor is off a bit there too. It can do much more than that too. It is around $30 and worth every penny. Running Windows 8 here.
Hi
I'm in the process of setting up my new monitor today.
Getting it synced between Photoshop and Indesign I was having some problems.
New computer and monitor.
I finally think I have it about set, and my desktop looks right.
I can see detail in the horse all over even in the thigh area, but it is dark, it also looks like it's supposed to look that way not like its under exposed if you get what I mean.
It doesn't look like an image that should be lighter and is too dark, if that makes any sense. Â You can see by the shadow that it's back lighted and that's how it looks.
Mike
If you shoot a mime, do you need a silencer?
http://www.lagom.nl/lcd-test/
All looks good on the test images, but I happened to load up a render I did a couple of weeks back and the black horse's torso (especially the backside) is practically a silhouette on both monitors; does it look that way to others?
Â
Thanx for any feedback...
"Oh - the manual says that? I have never read the manual - this must be why."“I could buy better software, but then I'd have to be an artist and what's the point of that?"
