Fri, Nov 22, 12:32 PM CST
Subject: Adobe Air update issues
ArtByMel ( ) posted Tue, 15 January 2013 at 9:33 AM · edited Fri, 22 November 2024 at 6:53 AM
Yesterday, while working in Poser, I received a notice about an update for my Adobe Air. No biggie. Clicked ok and install and kept on working. Not a problem. Closed out Poser and did not give it another thought.
Today when I opened Poser, my library would not open. It would start and then close down with an error. I tried it in both PP2010 and PP2012. I got the same error in both applications. The LSMGUIAIR exe stopped working with an unknown error. I searched the web and found nothing in reference to this particular error. Mind you, I never had a problem like this before. I even tried opening both the poser exe and the LSMGUIAIR exe as an administrator. No dice.
So, I thought maybe it was the Adobe Air update. I checked my system restore info, such as what programs would be affected if I did a system restore to an earlier point. There were only 2 and the Air update was one of them. The other was something I had installed to try and planned to uninstall anyway. I went ahead and did the system restore to an earlier date, wiping out the Adobe Air update. Guess what? Poser library is working again just fine.
Beware the newest Adobe Air update. You might run into the same issue that I did.
My store here at Renderosity.
Art By Mel
LaurieA ( ) posted Tue, 15 January 2013 at 9:38 AM
Hmm...I installed it too and haven't had any problems. I hope ya get it worked out :).
vitachick ( ) posted Tue, 15 January 2013 at 10:26 AM
I also had update...NP
Win10  Poser 2014/Poser 11 Daz3D
ArtByMel ( ) posted Tue, 15 January 2013 at 10:34 AM
Weird. And if wierd is possible, I'm it's girl. I'm just going to let things as they are and wait for the next update.
Art By Mel
Willber ( ) posted Tue, 15 January 2013 at 12:17 PM
Sorry to hear you are having issues with this.
Try this.
Control Panel / Programs / Programs and features
Select Adobe Air
Select Change and then select  REPAIR and see if it fixes the issue.
Willber ( ) posted Tue, 15 January 2013 at 4:46 PM
just cheked at home... Adobe Air does not have a repair option... sigh.
Possibly uinstalling and then reinstalling Adobe Air may fix it.
vilters ( ) posted Tue, 15 January 2013 at 6:39 PM
I installed that update with no problems at all afterwards...
All 4, Windows 7, 64 bit machines.
shvrdavid ( ) posted Tue, 15 January 2013 at 8:16 PM
If you ran the update with Poser running, it my be corrupted or an incomplete install.
Uninstall Air then reinstall it.
hornet3d ( ) posted Wed, 16 January 2013 at 2:31 PM
Quote - If you ran the update with Poser running, it my be corrupted or an incomplete install.
I clicked on the update while in Poser (P2012 Win 7 64 bit) without thinking but it updated and everything was fine but I guess it may depend on what Poser was doing at the point the update was performed.
