Mon, Feb 10, 8:34 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: New Carrara Store
Fenric ( ) posted Tue, 15 January 2013 at 12:15 PM · edited Sun, 09 February 2025 at 6:29 PM
http://fenric.com/wordpress/store/
I've got 5 useful new plugins for you to try.  Everything is try-before-you-buy, so there's no risk!
Supporting Carrara 7 and 8, Mac and Windows, 64 bit where available (except for Windows XP)
GKDantas ( ) posted Tue, 15 January 2013 at 1:19 PM
Got almost all plugins now! Thanks Fenric.
Follow me at euQfiz Digital
3doutlaw ( ) posted Tue, 15 January 2013 at 1:22 PM
Fenric, where do I find the command for the Shader Doctor...or did it just work already when I opened a PZ3, and I was not aware of it?  The Readme sort of implies that, but then it also says "all selected items"
...or I just completely misread it, which is the most likely problem  ;-)
I wanted to try it out.
3doutlaw ( ) posted Tue, 15 January 2013 at 1:26 PM
Oh, I found it, under Edit Menu, 3rd from bottom.
Fenric ( ) posted Tue, 15 January 2013 at 2:51 PM
It's hard to give exact guidance other than "In the Edit Menu".  Generally, under the "Fenric" sub-menu, but if you only have one then it won't be.
My "Fenric" sub-menu is very nearly as long as the main Edit menu itself. :)
animajikgraphics ( ) posted Tue, 15 January 2013 at 3:19 PM
Bookmarked!
-AniMajik
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
3doutlaw ( ) posted Tue, 15 January 2013 at 3:41 PM
Quote - It's hard to give exact guidance other than "In the Edit Menu".
True, but nothing actually says it is "In the Edit Menu" in the download  ;-)  Worked good!  I'll be buying it.
Fenric ( ) posted Tue, 15 January 2013 at 7:25 PM
Yeah, sorry...  As a developer, I'm too used to knowing that the Edit menu is the only place the commands will go.
I'll put some tips up on the download page to make it clearer.
booksbydavid ( ) posted Sun, 20 January 2013 at 8:46 PM
Grabbed a couple already. Very useful stuff. Will probably go back for more soon.
Thanks, Fenric! Keep'em coming. :)
headwax. ( ) posted Wed, 23 January 2013 at 7:46 PM
yes thanks Fenric - you are worth your weight in expensive metal :)
xiayu ( ) posted Wed, 23 January 2013 at 9:10 PM
Attached Link: Chinese translation to English
ah,it sounds good, useful for me
