Tue, Feb 4, 1:48 PM CST
Subject: depth of field, camera position in Poser 7
mystmaiden ( ) posted Wed, 23 January 2013 at 6:42 AM · edited Tue, 04 February 2025 at 11:27 AM
Hi everyone :) I have a two part question. I've been experimenting with building props and characters for a bit and found I've moved everything around so much and spun dials so often that I can't tell what camera is where. Is there a way to take all the cameras back to their default positions fairly easily? I need to get back to where I started from and give this another go.
I've been playing with seedydeedee's tut on depth of field this morning but it was made with Poser Pro - Poser 7 doesn't seem to have the little black targeting thing that lets you figure out exactly where the camera is pointed - either that or I am doing something very wrong. The first render I did came out perfect except for one little bitty issue - the building was perfectly sharp and the character was nicely blurred, lol.
I've looked for tuts on line specifically for Poser 7 and depth of field but I came across old broken links mostly or just vague instructions so any hints, tips or instructions would be great just now.
thanks,
mystmaiden
mysticeagle ( ) posted Wed, 23 January 2013 at 7:14 AM · edited Wed, 23 January 2013 at 7:17 AM
select the camera, then select **edit** from the top menu, **restore**,and scroll to **camer**a........is the only way i know, i think you must have to select each camera you have changed...........
OS: Windows7 64-bit Processor Intel(R) Core(TM) i5-2430M CPU @ 2.40GHz, 2401 Mhz, 2 Core(s), 4 Logical Processor(s)  6GB Ram
Poser: Poser Pro 2012 SR3.1 ...Poser 8.........Poser5 on a bad day........
Daz Studio Pro 4.5  64bit
Carrara beta 8.5
Modelling: Silo/Hexagon/Groboto V3
Image Editing: PSP V9/Irfanview
Movie Editing. Cyberlink power director/Windows live movie maker
"I live in an unfinished , poorly lit box, but we call it home"
My freestuff
 link via my artist page
mystmaiden ( ) posted Wed, 23 January 2013 at 8:35 AM
Thanks so much! Very helpful. I wonder, too, if maybe the other thing I need to do to start back over from scratch is to change the x,y, and z trans on everything in the scene back to 0. That'll be the next thing I try after repositioning the cameras
hborre ( ) posted Wed, 23 January 2013 at 8:41 AM
Yes, you must set each camera individually as Mysticeagle has illustrated.  In P7, your DoF marker is, IIRC, located under display.  Dr. Geep has a tute on how to use it on his site.
http://www.drgeep.com/p6/guides/guides.htm
Keep in mind, using DoF does require using higher pixel sampling for lower F-Stops which will increase your render time significantly.
Rance01 ( ) posted Wed, 23 January 2013 at 8:53 AM
You can also save your camera settings using the Camera Dots.  Also, there is a handy Depth of Field python script in the Python menu: Windows > Python Scripts > Render/IO > Calc DoF Focal Distance.
Looking through the camera you are going to use, click the object of your focus.  Stewer's script spits out the factor to use.
Nice thread here too: http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2014883
Best Wishes,
Rªnce
Rance01 ( ) posted Wed, 23 January 2013 at 9:00 AM
Should add, Under Edit menu, General Preferences, you can Launch to factory state.  That would be a good start to using a Camera Dot.  That way you have the default cameras saved in a Dot.
Modify the studio anyway you want, use Edit menu GP, to set your Preferred State, and then Launch to Preferred State.  You can use the UI Dots to save up to nine User Interface settings.  Same with Camera sets.  You can use the Poser Library to save cameras too, and Select Subset to save individual camera settings.
Be Well,
willyb53 ( ) posted Wed, 23 January 2013 at 11:07 AM
Poser 7 has a focus guide.  Just make sure you have the correct camera selected on the paramaters so you can chane the focus.
Bill
Rance01 ( ) posted Wed, 23 January 2013 at 11:49 AM
One other thing to remember when using Depth of Field is to raise Pixel sampling.  And, have patients.  It seriously increases render times.
0¿O
-O-
http://www.ranquist.net/junk2012/AntonAnts.htm
markschum ( ) posted Wed, 23 January 2013 at 5:36 PM
You should I think be able to save a camera pose. It might be a bit tedious to open a new scene , and then save all the cameras to a pose library, but you only have to do it once.
mystmaiden ( ) posted Wed, 23 January 2013 at 11:43 PM
I haven't played with saving my camera settings yet but I did manage to render something (just three hours to render the scene, lol) and come up with a dof that looks like I intended. Now whether it actually looks right remains to be seen.
Rance01 - I read through the forum post but honestly, I know nothing about cameras and it was so far over my head. I checked out the ants image. The fog was a very neat effect. How did you do that? My desire to play with dof came along ages back when an amazing image was posted to the gallery, there's fog in it too. (Riders in the Mist by Sabotssnake).
markschum - being able to save camera poses would be great, I'm going to experiment because for me the hardest part of Poser is getting the camera angles just right and keeping them that way.
Attached is my image before any postwork - just slapped some grey in the background. Be honest and say what you think. I'm not sure how effective the dof is in a semi indoor scene really.
Rance01 ( ) posted Thu, 24 January 2013 at 5:52 AM
Most excellent render.  Very nice.
The ants picture features DoF and Atmosphere Volume: focus_Distance 6.68; Depth Cue Start Dist 6, End Dist 24
The Depth Cue settings make the 'fog'.  The Atmosphere settings are found in the Material Room.  I changed the DepthCue_Color from  black to white and used the above start and end distances.  I'm not sure about Volume_Density, Stepsize and Noise, but I can check if you like ...
I used the same Python script I mentioned above to figure the focus_Distance.  I made certain I was 'looking through' the Main Camera, clicked on the leading ant's head, went to Window, Python Script, Render/IO, Calc DoF Focal Distance.  The script provided a factor to Copy and Paste into the Main Camera focus_Distance Parameter.
The script also provides a starting point for figuring where the Depth Cue should start and stop.  As I said above, I also raised the Pixel sampling AND lowered the Min Shading Rate to values higher and lower than anything I normally use.
Saving cameras shouldn't be a problem for you.  As above, use your Dots or save Cameras directly to the Library.
The Ants file is on another computer, and I will have to look there to see what Density, Stepsize and Noise I used.  Also, having more that bit of trouble typing right now ....
mystmaiden ( ) posted Thu, 24 January 2013 at 9:56 AM
Thanks for the great reply. I'm sorry I made you type all that. No need to look it up just now - maybe we can revisit it later when I get brave enough to try for some fog! Its a wonderful effect. I'm still playing with my image, not at all sure about the color of the lighting and the dress. I snagged her a new dress texture at daz last night and will re-render it today and see. This is definitely the most complicated render I ever attempted. Couldn't have accomplished it without the help I got right here.
Rance01 ( ) posted Thu, 24 January 2013 at 10:35 AM
Finding the settings is a snap.  The file is just saved to another computer than I was using this morning.  And it's not your fault I blathered on so much.  Just sometimes the fingers won't follow what the head is telling them to do.  I was having a rough time this morning ...
I posted the full Atmopshere settings on the Ants page - Depth Cue Start Dist 6, End Dist 24, Volume_Density 0.025, _SetSize 0.833333, _Noise 0.
I'm glad to be any help at all.  I've had plenty advice from wiser members of this forum.  It's a pleasure to post.
I think you have a great start to the project you are working on.
Be Well,
moogal ( ) posted Mon, 28 January 2013 at 6:31 PM
Quote - Attached is my image before any postwork - just slapped some grey in the background. Be honest and say what you think. I'm not sure how effective the dof is in a semi indoor scene really.
I love it.  That's very similar to the look I am going for (only more sci-fi).  I don't care if anything I do looks "right" if I think it looks good.
