Mon, Dec 2, 11:38 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: odd coloured rocks in vue 10
iborg64 ( ) posted Fri, 25 January 2013 at 4:44 PM · edited Mon, 02 December 2024 at 11:36 AM
I have some bought vue scenes , including vue live paintings bought from here in which many of the rocks have odd colours eg magenta blue or green in a landscape this just ends up looking like its strewn with litter , any one know whats wrong this happens when I load a scene as bought and just render with no changes other than render quality , usually set to broadcast or superior .
any help would be much appreciated
iborg64 ( ) posted Fri, 25 January 2013 at 4:59 PM
this is an example of what the rocks  end up like
Mazak ( ) posted Sat, 26 January 2013 at 9:17 AM
*(click on image for large view)* In material tab check eco-system materials if there colored quadrangles; left click them to deactivate the colored material preview. This is a feature to easy locate eco system objects in a scene. It should be deactivate for final render. I hope it help you.
Mazak
Google+ Bodo Nittel
iborg64 ( ) posted Sat, 26 January 2013 at 3:53 PM
sorry still cant get this right , i can get them all green or all pink but not normal
Mazak ( ) posted Sat, 26 January 2013 at 4:24 PM
*(from this)* Are you sure you left click the box on the right? With right click you only select another color.
Mazak
Google+ Bodo Nittel
Mazak ( ) posted Sat, 26 January 2013 at 4:31 PM
(to this)
Mazak
Google+ Bodo Nittel
iborg64 ( ) posted Sat, 26 January 2013 at 6:39 PM
this is how my scene looks in vue when it renders multicoloured rocks
iborg64 ( ) posted Sat, 26 January 2013 at 6:41 PM
I have been able to change the colours either to green or pink
iborg64 ( ) posted Sat, 26 January 2013 at 6:42 PM
green version
iborg64 ( ) posted Sat, 26 January 2013 at 6:43 PM
but unable to get normal colours
Mazak ( ) posted Sat, 26 January 2013 at 7:34 PM
hmmm... I run out of ideas...
Is there a strange Variable color like this: ? Turn it off...
Mazak
Google+ Bodo Nittel
iborg64 ( ) posted Sat, 26 January 2013 at 8:16 PM
no cant find anything like that i feel it must be something like you first suggested as thats how i changed the colours to all pink or all green , its also only on the few scenes that i have bought , quite a few ive bought are ok , and any i have done my self have never had this effect
iborg64 ( ) posted Sat, 26 January 2013 at 8:17 PM
also what does the symbol by red desert mean small box with zigzag line in it?
Mazak ( ) posted Sun, 27 January 2013 at 5:46 AM
This symbol is a 'Mixed material' . You can load alternative material for the rocks in 'EcoSystem Material' tab for example.
Is there a readme for this product? Can you contact the vendor for assistance? Maybe the product is not compatible with your version of Vue!?
Mazak
Google+ Bodo Nittel
Mazak ( ) posted Sun, 27 January 2013 at 5:55 AM · edited Sun, 27 January 2013 at 5:55 AM
The vendor is stamate_filip. Here you can contact the vendor: http://www.renderosity.com/homepage.php?page=1&userid=24138
Mazak
Google+ Bodo Nittel
iborg64 ( ) posted Sun, 27 January 2013 at 6:08 AM
yes i have contacted the vender so far he asked me which version i bought and which version of vue I have not had a reply back from that yet (i have checked from my download list here I have the correct version for vue 10 xstream ) so am awaiting further reply
Many thanks for your help so far although I have not resolved this problem yet your help is much apreciated
Mazak ( ) posted Sun, 27 January 2013 at 6:22 AM
stamate_filip has excellent reputation and will be fixed fast your problem. Maybe there is a delay because of weekend.
Good luck.
Mazak
Google+ Bodo Nittel
aeilkema ( ) posted Mon, 28 January 2013 at 4:20 PM · edited Mon, 28 January 2013 at 4:25 PM
Attached Link: http://www.renderosity.com/mod/forumpro/media/folder_10/file_491071.jpg
Can you show us the material settings you do have, just as Mazak has done in the link, perhaps that can give some clues?
I'm fairly new to Vue, so I may not be of much help, but perhaps by showing the mats someone can see what's going on.
Food for thought.....
iborg64 ( ) posted Mon, 28 January 2013 at 5:25 PM
i will try but not sure where to start so here is first screen shot if not right maybe you can tell me where to go to/from
iborg64 ( ) posted Mon, 28 January 2013 at 5:27 PM
oops file size too big try again
aeilkema ( ) posted Tue, 29 January 2013 at 1:39 AM
May be silly. but what happens when you apply a different material? (Perhaps save the original one first and then apply a different one). I'm assuming all will be fine then. What happens if you start a new scene and use these rocks with material, does the same thing happen?
ShawnDriscoll ( ) posted Tue, 29 January 2013 at 2:30 AM · edited Tue, 29 January 2013 at 2:31 AM
Did we ever find out what iborg64's Material Browser looks like?
iborg64 ( ) posted Tue, 29 January 2013 at 12:56 PM
sorry folks excuse my lake of knowledge I am not sure how these rocks were created I have only ever used rocks supplied in vue to use on eco systems and they all work fine I am not sure exactly what material editor you need to see sorry supplied anothe rscreen shot any help?
iborg64 ( ) posted Tue, 29 January 2013 at 12:57 PM
these rocks just from vue which I thought at first were what had been used work fine
ShawnDriscoll ( ) posted Tue, 29 January 2013 at 3:30 PM
Third post down.  There is a red circle.  What is your Vue doing there?
iborg64 ( ) posted Tue, 29 January 2013 at 4:59 PM
Mindful I am not at my pc at the moment I'm using my phone the seventh post down shows screen shot of the same area clicking on there was able to change the problem rocks to either all green or all magenta but not to normal
iborg64 ( ) posted Tue, 29 January 2013 at 5:01 PM
This evening I have tried all the rocks I have in empty scene All Render correctly
ShawnDriscoll ( ) posted Tue, 29 January 2013 at 5:22 PM
That one is not showing up for some reason.
iborg64 ( ) posted Tue, 29 January 2013 at 7:07 PM
ok i will try and upload that screen shot again
iborg64 ( ) posted Sun, 03 February 2013 at 9:10 AM
Although I have been unable to fix directly I have been able to get awork around by deleting the rock layer and painting my own I can then save that and for now that is a satisfactory solution many thanks for all the help and in particular to the vender stamate_filip who was most helpful and offered me something else from his store which i had and I am most satisfied with the out come
