Wed, Dec 4, 8:27 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 4:13 pm)
Subject: Any free blue skin or drow skin for Micheal 4?
TheOwl ( ) posted Sun, 27 January 2013 at 7:11 PM · edited Wed, 04 December 2024 at 8:07 PM
I looked and looked but I couldn't find any skin that is blue in color or drow to use in Micheal 4 so that I can make him look like a genie.
The only free ones I see are for V4!
Passion is anger and love combined. So if it looks angry, give it some love!
willyb53 ( ) posted Sun, 27 January 2013 at 8:04 PM · edited Sun, 27 January 2013 at 8:05 PM
Since no one has come up with one, you can do your own in the material room.
You can disconnect the diffuse texture, add a math (math functions, not color math) to the diffuse, and run the texture into the math, which will give you a gray scale image, and then put the desired color in the diffuse color chip.
 Of course you have to do it to all surfaces
bill
TheOwl ( ) posted Sun, 27 January 2013 at 8:32 PM
Wow. Looks like the simplest solution is always the best. Thanks for the suggestion.
genie
hborre ( ) posted Sun, 27 January 2013 at 10:17 PM
If you use an HSV node instead you can also control saturation and brightness.
EricofSD ( ) posted Mon, 28 January 2013 at 2:08 AM
Try this. In the DIffuse Color, temporarily disconnect your image map for your texture.  Add in a blender node.  Hook input 1 to a 2d texture and select an image file.  Probably just a square photoshop of the exact color you want.  Hook up input 1 to the original texture you had.
You can move the blending number up or down to increase or decrease your color.
templargfx ( ) posted Mon, 28 January 2013 at 2:22 AM
Rather than a texture, could use a math->simple_color node in the above blender.
I personally would use a HSV node as mentioned above for better control over the skin colour.  With the HSV node, remember that you can manually type values greater than the dials will allow.  this is a godsend if you didnt know.
TemplarGFX
3D Hobbyist since 1996
I use poser native units
167 Car Materials for Poser
EricofSD ( ) posted Mon, 28 January 2013 at 3:53 AM
hsv has a lot to offer and including that is a good idea.  This blender node thingie was for folks who want to keep their current texture map and just give it a color shade.
I'd love to see a screen shot of the blender with hsv
