Sun, Feb 2, 4:44 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
Subject: Specular
Sheedee ( ) posted Sat, 02 February 2013 at 8:39 AM · edited Sun, 02 February 2025 at 4:38 AM
Howdy;
Some expert advice please:
Been struggling with this for a long time.
After i pose my character i add an IDL STUDIO specular light to the scene...but the specular lights position is not correct on her eyes as you can see (please click on image for full screen)  i have no idea why this happens...nor how to solve it...the two little white specular dots should not be at the bottom of her eyes...and i know that this is avoidable because i have seen many renders where those little dots are correctly positioned.
thanks for viewing
God bless.
hborre ( ) posted Sat, 02 February 2013 at 9:23 AM
I do not have IDL STudio, however there has to be a specular based light somewhere in the set.  IDL will only emit diffuse lighting, the key light will contain both diffuse and specular.  You can check this in the material room.
hornet3d ( ) posted Sat, 02 February 2013 at 10:54 AM
When I have used specular for this in the used as a spot the position of the highlight in the eyes is dependant on just where that spot is placed.  I normally point the spot at the models head and then move the light directly in front of the model adjusting the height of the light to lift the highlight to the upper eye.  I then tend to move the light left or right to move he highlight off centre.
hborre ( ) posted Sat, 02 February 2013 at 12:42 PM
Unless, of course, the specular highlights are baked into the texture.  In which case, no matter where the spot is located, the highlights will still appear in the same place.
hornet3d ( ) posted Sat, 02 February 2013 at 1:23 PM
Quote - Unless, of course, the specular highlights are baked into the texture.  In which case, no matter where the spot is located, the highlights will still appear in the same place.
Yep that is another possibilty but if baked in I would expect them to be more central, I never use a baked in highlights with the eye so I must admit I didn't think of that possibility.  It does make it more important when placing the lights but I think it looks more natural, assuming of course the model is close enough for the highlights to make a difference.
