Wed, Feb 12, 6:23 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Python Script Request for Poser Pro Pack
sturkwurk ( ) posted Mon, 10 September 2001 at 10:07 PM · edited Sat, 08 February 2025 at 11:42 AM
I'd like to see three new scripts made... Prop Clipboard... so you can copy a prop and paste it... Magnet Mirror... so you can place magnets on one fore arm for example and make them mirror to the other fore arm with the same settings. Morph Mirror... so you can just create morphs for half a file and mirror them to the other half. Am I asking for something too complex... heck I'd gladly pay for them in a package similar to the MK scripts that Daz just posted last week. Thanks, Doug
I came, I rendered, I'm still broke.
Mason ( ) posted Sat, 15 September 2001 at 1:55 AM
The magnet mirror would be doable. The prop clipboard supposedly can be since you can copy geometries. The Morph Mirror probably can't. MTs require exact vertex information in the exact order the mesh is created. I know the characters are not perfectly symetrical so MTs mirrored to the right arm from the left probably won't work.
jbrugion ( ) posted Sat, 15 September 2001 at 10:15 AM
Actually, there is a way to do the morph mirroring. If the character is symmetrical or near symmetrical (which requires a long explanation) then there is a very simple brute force way of mirroring the morph. Daz has been using my script for this for a number of projects and now that the V2 clothes pack is done I may go ahead and wrap a GUI on the script and put it out for everyone. It would have been out sooner but we ran into an "issue" in the Poser Pro Pack that was causing a massive ( it ate my 512 MB system) memory leak. I now have a work around for the problem and will see about getting it out. CL was informed of the "issue" and is investigating it.
DraX ( ) posted Wed, 24 October 2001 at 12:07 AM
That sounds, great, jbrujoin.... I would LOVE to see it available.
