DAZ|Studio F.A.Q (Last Updated: 2025 Jan 11 12:30 am)
http://www.aldaraproject.com/aldara/
http://www.dreamslayervisions.com
ds4.5 it is then, my favorite app...should be able to have this ready sometime next week. now i'll have to see how well it autofits to genesis while im playing...lol
got hung up this week with reallife work, so will get this finished up this weekend.
I just need some hardy souls to offer to test it...once i know it works on someone elses machine it will be ready to go public!
pm me to test it out.
kisses
SS
Mino and Pop you have site pm .
post here for issues you find.
thanks
SS
On a V4.5 model> shin and Thigh controls do not move parts of dress. elbow pook through when posed no adj for that. get break in seems at underarms when upper arm is clost to torso. fits most all sizes of model can inflate some to fit. shin control effects part of thigh. Needs lower back him adjustment comtrol has a kick back that is way back off shoes, loads with no texture but does accept when added. needs better chest ajust ments for nippls, brest size etc... and torso thickness ajustment work but not on brest area could use different lableing of dials. Sash texture needs to be a darker or lighter blends into dress hard to see in renders I changed the defused color to a darker green and it shows up in renders. In all just minor tweeks are needed it looks fantastic shape style all work great I can see a lot of good use for this dress. Will not work on V4 or V5 that is Genesis bassed, If you like I can post renders of this so you can see how it looks in renders. Every artest will have to make some djustments as in all items but these need a bit more atention. Thanks again for your trust.
In poser format> handels work both sice not just right or left When fitted to model cannot use handels they conect to the model bones not the dress has no chest adjustments that adjust the bust will fit V5 in poser format Follows most poses with few pook throughs handels cannot be used to fix any pook throughsor adujust and flowing of dress. no adjust can be made in sitting pose.
did you read the instructions in the readme?
this is a ds4.5 dress for v4 not v5, it should autofit to v4 and then you need to add the smoothing modifier to collide with her automagically adjusting to her breasts and elbows?? if you select the rthigh and lthigh it should move the skirt also..
as with most skirts it doesn't do sitting poses.
in the poser cr2 the handles dont move the skirt??? it should.
i'll recheck these items as well.
please read the step by step instructions in the read me and try again.
anymore testers out there?? pm for the download.
Yes I did read as per your text. and worked it as it stated I also did try it in DAZ3 and serpriseingly the poser format did load into DAZ3 but with the same effects. I tried it just to see if the poser format would and it did looks great as well. I love how it will resize to almost any scale. But I lean to smaller busted models and without a better chest and bust control and adjustments it will have to be used on the standard V4 bust type of model. I will continue working with it and report back to you as I go.
Minotaur did you add the collide against? that may help with the nipples you used.
yes its modeled to the regular v4 bust shape. other extream morphs may need special morphs created to accomidate them.
the poser version should work in ds3 but not the duf files.
question try uping the collide against dial and see what happens?
i'll retest it with a few other breast shapes also and see what i end up with.
it was released see the freebies forum.
do you need it in ds format or poser runtime?
side note: i just want to say shame on you , who ever charged for that other dress you gave this person..........:(
this will fit v4++ morphs, has adjustment morphs
movement handles on the skirt , and the sleeves have a separate material so you can make them invisable for a strappy look.
its two pieces, the dress and the sashbelt with the medalion, as a prop item for the hips.
no textures yet, wips have ds shaders applied.
www.bloodyrosesdesigns.com
