Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
It's a cr2. Look under the path you installed the content to when you first installed Poser. It should be in this path:
[YourMainContentFolder]RuntimeLibrariesCharacterWalkDesignerRyan_WD.cr2
E.g:
My DocumentsPoser Pro 2012 ContentRuntimeLibrariesCharacterWalkDesignerRyan_WD.cr2
If it's not there you may have accedentally moved or deleted it. If it's not there, do a Search of you your HDD for "Ryan_WD.cr2", and move it to the correct location. If it is not found on your HDD, do an over the top re-install of Poser to the same path that you installed to originally.
So my Walk Designer is suddenly broken... using PPro 2012, it used to work fine now it says Ryan_WD is missing, no clue what that is or where to find it.
Any tips?
