Vue F.A.Q (Last Updated: 2024 Oct 17 8:34 am)
I have the same problems with skin vue and python in Vue 11, because it's very difficult to install skin vue in the correct way. In the tutorial of skin vue is the installing process of Vue 7 or 8.
The attached skin vue tutorial ist given unfortunately a completely outdated description of the installation which more confused than help. Unfortunately, the vendor hasn't updated this information for a long time.
And with every Release of Vue, I have the same long problems of installing skin vue and running python on the correct way.
I've never had a problem installing SkinVue for Vue Infinite since version 7 thru 10/Elite. I'm using WinXP 32-bit though.
I am using Win7 64 bit. Never had any issues with installing SkinVue either. All that was needed is to copy the SkinVue folder into /Program Files/e-onsoftware/Vue 11 Infinite or whatever version I was using at that time. Separate install of Python was not needed since version 9 if I recall correctly. This aplies to Vue Infinite. It could be that your issues are specific to xStream.
Ciao
TD
I wouldn't move any folders. Just copy the skinvue folder to where the instructions say to.
Don't worry if your C: path name does not match the instructions. Just worry about the folder and filenames in your path name (which do match the instructions), and where you are copying the SkinVue folder.
After some back and forth with forums and support I come back to here and hope for the final advice.
I couldn't manage the run of SkinVue.
I have tried to
install
reinstall
move folder form a to b
changed the permissions of the folders
nothing helped! Same problem and same message. I have tried other pythons with success.
Please to all lucky users, can you tell me the exact installation of your skinvue?
What I did. I have installed skinvue to
programse-onsoftwareVue11xStream(vc100)SkinVue
D oyou have any
wx
wxpython
folders installed somewhere else ? I think of .../Python/PythonLib/
or .../Python/PythonLib/site-packages.
Please can you check for WX folders? Do have such folders inside your vue-folder? If yes, where?
Meanwhile I have deleted all tries of moving wx-folders.
Would be great if someone could give the final clue...
Thanks
Daniel
Just want to let you know we have solved the Problem. We think SkinVue is not running with
Vue11Pro_vc100
After we had installed
Vue11Pro
SkinVue opened is console and let us run this Software. We also installed Vue11Pro with the lowest user's permission. Don't know if this was the problem-solver.
Daniel
Hi all.
In these days we proudly got our version of VUE Xtreme 2014. Again we have the same issue. Analyzing all of our experience out of the past, obviously it depends on the version you have installed.
Going back to 2013:
First we tried VUE11 Xtreme (VC100). There was chance to run SkinVue anyway. Be sure we tried everything. After we had installed VUE11 Xtreme without the (VC100), SkinVue started without a problem.
Now we have the same issue with VUE Xtreme 2014.
VUE Xtreme 2014 (VC100) causes the error message like shown above.
Version VUE Xtreme 2014 (without (VC100)) let SkiinVue run without an error.
My personal thought is that SkinVue doesn't run, if the (VC100) Version is installed.
I'm going to contact e-onsoftware again and perhaps there is solution for this available.
Does anybody in here have VUE2014 (VC100) and SkinVue installed?
SkinVue is written for a specific version of Python. What version of Python does Vue come with now?
Hi All.
We have found a happy end, becuase SKINVue Elite is running with VUE Xtreme 2014. With the help of Lee from e-onsoftware.com we could fix the problem.
To implemnent SKINVue due to their description you need a vue installation without the interface to external programs like Cinema or 3DMAX. The standalone VUE Xtreme 2014 doens't has difficulties with SKINVue. So we have two installation running
The versions are installed in different folders
We have our vue11 version running on Win7, 64bit. It looks fine so far but we have problems in installing
SkinVue_Elite_Vue_23_1
When we try to run skinvue inside Vue11
Skinvue.py
The error 'wxPython not installed correclty or not found.
We have searched this forum but couldn't found a note regarding this problem.
What we did
Moved folder SkinVue to programse-onsoftwareVue11xstream(vc100)
Moved folder wx and wxPython to ...PythonPythonLibsite-packages
Moved folder wx and wxPhyton to ...PythonPythonLib
We have checked the permission and changed to full access.
Hope you have some good advices or links. Would be great.
Thanks
Daniel
