Thu, Nov 28, 1:57 AM CST
Subject: wxPython Error in Vue11
kruse ( ) posted Wed, 13 February 2013 at 3:47 PM · edited Tue, 26 November 2024 at 1:18 AM
We have our vue11 version running on Win7, 64bit. It looks fine so far but we have problems in installing
SkinVue_Elite_Vue_23_1
When we try to run skinvue inside Vue11
Skinvue.py
The error 'wxPython not installed correclty or not found.
We have searched this forum but couldn't found a note regarding this problem.
What we did
  • Moved folder SkinVue to programse-onsoftwareVue11xstream(vc100)
  • Moved folder wx and wxPython to ...PythonPythonLibsite-packages
  • Moved folder wx and wxPhyton to ...PythonPythonLib
We have checked the permission and changed to full access.
Hope you have some good advices or links. Would be great.
 Thanks
Daniel
bruno021 ( ) posted Wed, 13 February 2013 at 5:07 PM
There is a similar thread at cornucopia with SV Elite and Vue10, maybe it will help with your Vue 11 issue.
Amigo968 ( ) posted Wed, 13 February 2013 at 5:34 PM
I have the same problems with skin vue and python in Vue 11, because it's very difficult to install skin vue in the correct way. In the tutorial of skin vue is the installing process of Vue 7 or 8.
The attached skin vue tutorial ist given unfortunately a completely outdated description of the installation which more confused than help. Unfortunately, the vendor hasn't updated this information for a long time.
And with every Release of Vue, I have the same long problems of installing skin vue and running python on the correct way.
ShawnDriscoll ( ) posted Thu, 14 February 2013 at 7:23 AM
I've never had a problem installing SkinVue for Vue Infinite since version 7 thru 10/Elite.  I'm using WinXP 32-bit though.
Amigo968 ( ) posted Thu, 14 February 2013 at 9:30 AM
I use Win 7, 64 Bit and there is not the correct installing tutorial and also the python doesn't work.
thd777 ( ) posted Thu, 14 February 2013 at 10:04 AM · edited Thu, 14 February 2013 at 10:06 AM
I am using Win7 64 bit. Never had any issues with installing SkinVue either. All that was needed is to copy the SkinVue folder into /Program Files/e-onsoftware/Vue 11 Infinite or whatever version I was using at that time. Separate install of Python was not needed since version 9 if I recall correctly. This aplies to Vue Infinite. It could be that your issues are specific to xStream.
Ciao
TD
Amigo968 ( ) posted Thu, 14 February 2013 at 12:20 PM
Look at here please
ShawnDriscoll ( ) posted Thu, 14 February 2013 at 12:29 PM
I wouldn't move any folders.  Just copy the skinvue folder to where the instructions say to.
Amigo968 ( ) posted Thu, 14 February 2013 at 12:55 PM
But the instructions are for XP and not Win 7, so I have the program on c: and the folders on E:
The instructions are not very helpful.
ShawnDriscoll ( ) posted Thu, 14 February 2013 at 1:26 PM
Don't worry if your C: path name does not match the instructions.  Just worry about the folder and filenames in your path name (which do match the instructions), and where you are copying the SkinVue folder.
kruse ( ) posted Sun, 10 March 2013 at 8:36 AM
After some back and forth with forums and support I come back to here and hope for the final advice.
I couldn't manage the run of SkinVue.
I have tried to
  • install
  • reinstall
  • move folder form a to b
  • changed the permissions of the folders
nothing helped! Same problem and same message. I have tried other pythons with success.
Please to all lucky users, can you tell me the exact installation of your skinvue?
What I did. I have installed skinvue to
programse-onsoftwareVue11xStream(vc100)SkinVue
D oyou have any
wx
wxpython
folders installed somewhere else ? I think of .../Python/PythonLib/
or .../Python/PythonLib/site-packages.
Please can you check for WX folders? Do have such folders inside your vue-folder? If yes, where?
Meanwhile I have deleted all tries of moving wx-folders.
Would be great if someone could give the final clue...
Thanks
Daniel
kruse ( ) posted Sun, 24 March 2013 at 8:18 AM
Just want to let you know we have solved the Problem. We think SkinVue is not running with
Vue11Pro_vc100
After we had installed
Vue11Pro
SkinVue opened is console and let us run this Software. We also installed Vue11Pro with the lowest user's permission. Don't know if this was the problem-solver.
Daniel
kruse ( ) posted Wed, 15 January 2014 at 6:08 AM
Hi all.
In these days we proudly got our version of VUE Xtreme 2014. Again we have the same issue. Analyzing all of our experience out of the past, obviously it depends on the version you have installed.
Going back to 2013:
First we tried VUE11 Xtreme (VC100). There was chance to run SkinVue anyway. Be sure we tried everything. After we had installed VUE11 Xtreme without the (VC100), SkinVue started without a problem.
Now we have the same issue with VUE Xtreme 2014.
VUE Xtreme 2014 (VC100) causes the error message like shown above.
Version VUE Xtreme 2014 (without (VC100)) let SkiinVue run without an error.
My personal thought is that SkinVue doesn't run, if the (VC100) Version is installed.
I'm going to contact e-onsoftware again and perhaps there is solution for this available.
Does anybody in here have VUE2014 (VC100) and SkinVue installed?
ShawnDriscoll ( ) posted Wed, 15 January 2014 at 8:30 AM
SkinVue is written for a specific version of Python.  What version of Python does Vue come with now?
kruse ( ) posted Fri, 17 January 2014 at 11:06 AM
Hi All.
We have found a happy end, becuase SKINVue Elite is running with VUE Xtreme 2014. With the help of Lee from e-onsoftware.com we could fix the problem.
To implemnent SKINVue due to their description you need a vue installation without the interface to external programs like Cinema or 3DMAX. The standalone VUE Xtreme 2014 doens't has difficulties with SKINVue. So we have two installation running
  • VUE Xtreme 2014 without the interface to external programs and SKINVue
  • VUE Xtreme 2014 (VC100) with the interface to external programs without SKINVue
The versions are installed in different folders
  • programse-onsoftwareVue 2014 xStream-VC90  (for working with SKINVue)
  • programse-onsoftwareVue 2014 xStream (vc100)  (for working with interface)
