Sat, Feb 8, 10:46 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: shader question
restif ( ) posted Wed, 20 February 2013 at 9:15 PM · edited Wed, 05 February 2025 at 2:55 PM
I know I've read or seen somewhere about how to correct the facets on this. Think maybe something Mark Bremmer said in one of his training videos, but I am unable to locate.
Anyone have suggestions on how to smooth out the facets in this ring? I've smooted the geometry but no luck.
Likely it is something simple that I am just missing.
Thanks for any help.
GKDantas ( ) posted Wed, 20 February 2013 at 10:28 PM
You need to select all polygons, and menu:
Model / Smooth Edges
Use the all option and hit OK. I think that you see all those polygons in yellow, this means that they have creased edges and even you using ths smotth option from painel, it wont smooth. After use this option in the menu it will turn to red (whem setected).
Follow me at euQfiz Digital
restif ( ) posted Thu, 21 February 2013 at 6:49 AM
Thanks I'll give this a try. I appreciate it!
Kixum ( ) posted Thu, 21 February 2013 at 7:42 AM
There are a few things here.
1.)  If this is a spline object, you need to increase the surface fidelity.
2.)  If this is vertex object, you can first select all vertices and smooth all vertices as GKDantas has suggested as a first try.
3.)  If step 2 doesn't work, you can select any part of the mesh in the vertex modeler to bring up the vertex smoothing option.  Then select the level you want to smooth things out.  One hitch though is that if you do this it will change the shape of the object so this might not be what you're up for.
-Kix
restif ( ) posted Sat, 23 February 2013 at 11:50 AM
 I thank you for the suggestions! I'm sure these will help!
