Sun, Feb 16, 8:19 AM CST
Subject: Convert V5 map to a V4 map?
Latexluv ( ) posted Sat, 23 February 2013 at 11:37 PM · edited Tue, 11 February 2025 at 5:25 PM
I hope this doesn't sound like a dumb question. I did not thoroughly read the description over at DAZ a few months back when I was buying a merchant resource base. I thought I was buying a resource base for Victoria 4 but it is for Genesis V5. Is there some way to convert this to V4 so I haven't wasted my money on this purchase?
Weapons of choice:
Medzinatar ( ) posted Sat, 23 February 2013 at 11:46 PM
you can use Map Transfer in DS.  It will transfer V4,V5,M4,M5 plus others
Latexluv ( ) posted Sat, 23 February 2013 at 11:59 PM
I'm sorry, I don't use DS at all. I installed it once and it didn't play well with Poser on the same machine. Poser renders would stall, so I uninstalled it. Is there any other way to convert this map?
Weapons of choice:
hborre ( ) posted Sun, 24 February 2013 at 12:03 AM
I don't believe there is another way
Medzinatar ( ) posted Sun, 24 February 2013 at 12:12 AM
Quote - I'm sorry, I don't use DS at all. I installed it once and it didn't play well with Poser on the same machine. Poser renders would stall, so I uninstalled it. Is there any other way to convert this map?
AFAIK, Poser and DS don't know about each other and not share any resources.  I have no idea what might have caused your problem.
In any case, Map Transfer is only utility out there.  No 3rd party has put one out yet.
Worth mentioning is fact you have to have V5 character installed to convert her textures because it uses UV coordinates from that model.  Same with other textures maps.
Latexluv ( ) posted Sun, 24 February 2013 at 12:43 AM
Okay, well that bites it then. I had trouble with DS so I took it off my system and I wasn't going to spend any money on Genesis anything. So looks like I blew money on that resource base. It will teach me to read more carefully before I buy. Thank you all for your help!
Weapons of choice:
BionicRooster ( ) posted Sun, 24 February 2013 at 2:24 AM
Forum Moderator
Explain your situation to Daz, I believe they have a decent refund policy.
Poser 10
Octane Render
Wings 3D
Latexluv ( ) posted Sun, 24 February 2013 at 2:41 AM
Oh, it was months ago, sometime last fall when I bought the product and just now got around to opening it up to have a look. I'm most likely out of luck. Too bad that the base wasn't for both V4 and the new V5, then I'd be cooking with fire. Ah, well. Thanks for the help!
Weapons of choice:
icprncss2 ( ) posted Sun, 24 February 2013 at 7:04 AM
If you have the DSON installed into Poser and all the files installed, go the Mec4D's site.
IIRC, she has a python script that works with DSON and changing UV's.  I didn't bother with it because I ended up dumping DSON, Genesis and all related files as too fiddly and time consuming.
Also check Dimension3D's site.  He has some scripts for the DSON as well.
I don't know if 3D Universe will add plugins for Texture Convertor 2 that would allow conversion between the Gen 4 and Gen 5 textures.  You could always email and ask.
hborre ( ) posted Sun, 24 February 2013 at 7:42 AM
There has been no plugin upgrades for that app for quite some time.  I doubt if the effort will be made.
