Community Center F.A.Q (Last Updated: 2025 Jan 10 5:03 pm)
Title and artist name could do with a bit more space in the gallery thumbnails - they get overlapped a bit at the bottom by the gallery name.
FireFox 19 if that makes any difference
My Freebies
Buy stuff on RedBubble
Not only the artist names need more space, The site has some serious issues when rezising the window (at least with IE). The lay-out gets all messed up. The white bars are smaller than the text/product pictures/ prices overlap the purchase button etc.
Have a large monitor and like to keep the side on one half, but it almost becomes unreadable.
Client used is very important in fixing issues. Most of the following is in FF19, Chrome 25 or otherwise noted.
Issues broken down by type:
Responsive Design
Site clearly has responsive design. I can view it at several differnet breakpoints in Firefox 19 on Windows 7.
1280 v 600 (Landscape) = Fine
1280 x 600 (Portrait) = Broken Layout (Sidebars correctly display under main content, but broken)
1280 v 980 (Landscape) = Fine
1280 x 980 (Portrait) = Broken Layout (What's hot images bleed out of the side bar)
1280 x 800 (Landscape) = Fine
1280 x 800 (Portrait) Broken (What's hot images bleed in the side bar, same with calendar in sidebar)
1024 x 768 (Landscape) = Broken (Sidebar bleeds out, see above)
1024 x 768 (Portrait) = Broken (Sidebar has several issues)
360 x 640 (Landscape) = Broken
360 x 640 (Portrait) = Broken
Gallery Thumbs shrink as expected, but with no max height or width exceed their normal sizing and become distorted.
The white boxes the thumbnails sit in on category level pages becomes uneven at some resolutions (IE - breaks).
Was unable to invoke the 'mobile' layout as expected on a iPoD Touch (4th Gen) or a Samsung mp3 Player (Android 2.3, stock browser). Both got the desktop layout.
Firefox is picking up a global style for the paragraph element giving it a 10px bottom margin. This really screws with the spacing on posts. This is on like 547~ in bootstrap.css Global styles are bad.
Usability
On a mobile device: Clicking into the user name field works, select 'next' moves to password as expected, select 'next' moves to search box. This should move to the login button.
On some Display breakpoints the Global Navigation disappears. It is not very obvious that the box along the right side will display it. The box has no marker or indication of function.
Page Structure
Quick scan of markup, by no means exhustive.**
Also in the past few hours bouncing around the site..
I have seen JavaScript warnings due to the script being non-ECMA compliant, and a load of CSS warnings.
Example:
font-style:bold;
instead of font-weight: bold;
Also several references to MS filter style rules, and even some pages reporting they are being rendered in Quirks mode.
Your pages could render faster with less repainting with proper markup, CSS, and JavaScript coding practices.
Marketplace Content:
Wishlist:
Product name wraps around image.
Image too large. I can only view 2 1/2 images at a time. Half the size would do.
My Gallery:
Forrum:
I am using IE8 and Windows 7 on a Toshiba Satellite widescreen laptop.
The 'Galleries' link doesn't appear to be working only the options in the drop down list, and the same is true of the main Forum link. Is this a bug or is it designed this way?
Links "Galleries", "Freestuff" don't appear with new RR. :((((
The galleries link is available with right click , then new tab.
http://www.renderosity.com/mod/gallery/index.php
Thumbails are too big in galleries. And manes in fact are 'eating'; on y, j, g... letter.
The site appears deformed, the band blancest too high for my screen parraport to before.
Hello!
I search freestuff with names of artist. And for one (only one), I have a whole lot of lines ofbugs who appears.
Not whole capture.
Page in question is this: http://www.renderosity.com/mod/freestuff/index.php?user_id=641216
"What's hot today" hotbutton is working on some pages and not others. E.g.:
It is working on this page:
http://www.renderosity.com/mod/sitemail/mailbox.php
It is not working on this page:
http://www.renderosity.com/mod/gallery/index.php?image_id=2417050
IE 8, Windows Vista
Quote - Hello!
I search on Freestuff, then Search Freestuff.
In case: Search specific user? I tap TruForm.
I don't know why. I did that only. I relaunched the page several times on my side, in vain.
And opening another tab to test other artists, the error does not occur to them.
the relaunching wont help i had a similar issue,a while ago with something else.you have to clear the cookies and history otherwise it loads always the "error"page out of its cache.
What is a friend? A single soul dwelling in two bodies. -
Aristotle
Glass Eye Photography =- -= My Rendo Gallery =-
I said megapixel, not megabyte ;)
The logo is 3392x788 and it's scaled back with css to a width of 288 pixels, that's just stupid. That's why it renders so ugly.
Aristotle
I Can't upload an image to my gallery.When I click save and upload, the page just sits and sits. I have waited for maybe 5 lifetimes now and nothing. I have cleaned out my cache and temp files, logged in and out, rebooted. I can do everything else, purchasing, browsing galleries you name it, but nothing with my gallery. The image dimensions and file size are fine. I'm using IE9, Windows 7.
I don't know what else to do
I'll check with the techs for you Maddelirium. I don't think this particuliar issue would be caused by any of the recent site changes but even if it's not they may have some suggestions on what might be causing this for you.
And just to be clear, you don't receive any type of error message?
Also since it's the weekend and not sure how long it will be before I get the techs response, if you want you can email me the image and I can do some testing on my end with it to see if maybe I can help.
Thanks
Stacey:
Looking through comments from users the single most common complaint is still the tiny text box. I am not a web master but people who are are saying this is an easy fix. Almost all your users are working most of the time on laptops or desktops, not ipads or iphones (and I have both, and the box is lousy in them too). We need to have a decent text entry system.
Despite what some people (e.g. Sabby) are saying there is no drag box in IE 7, 8 and 9 on any windows system less than 8. I run all 3 systems and nothing is working in this regard.
Why is this "simple" problem not being addressed?
Quote - Despite what some people (e.g. Sabby) are saying there is no drag box in IE 7, 8 and 9 on any windows system less than 8. I run all 3 systems and nothing is working in this regard.
The drag is only in Chrome and Firefox. ;( This was mentioned by an admin somewhere, I think it was Stacey. I know that doesn't help you. It also doesn't work in IE10.
I believe it was also suggested someplace by an admin that IE users swap to Chrome...
Renderosity Store :: Daz3D Store :: Facebook
The issue has been mentioned, but I feel it needs to be said again. The small box for writing and commenting needs to be fixed or returned to its original format/size. Switching to another browser is not a fix. At this point I am wondering if there is going to be a fix, some sort of notice or repy is appreciated.
Thanks,AD
Quote - The issue has been mentioned, but I feel it needs to be said again. The small box for writing and commenting needs to be fixed or returned to its original format/size. Switching to another browser is not a fix. At this point I am wondering if there is going to be a fix, some sort of notice or repy is appreciated.
Thanks,AD
Sorry but I have to agree with this. Switching to another browser is not a 'fix'. It's a bandaid. I do appreciate that a lot of things have been fixed, then again the change should not have been published until it was beta-tested on all browsers. Many of us have mentioned/complained about these tiny comment/text boxes since the change over and nothing's been done to address that. :huh:
Thanks!
Ray
The smiies link above the reply box is broken...
Aristotle
Search page for forum is not found, this evening???
Not receiving e-bots and the system seems to be on the fritz in general... seeing mysql errors every now and then.
Aristotle
I am using IE8, on a flat screen, with my desktop. there were only 2119 people on line here at the time. Site is SLOW and gave me a lot of trouble trying to get the product names to appear.
I will NOT change my viewer for a website.
Life Requires Assembly and we all know how THAT goes!
A bug that was present and apparently solved earlier is back. A 'null' image is inserted in every post. Hence the extra whitespace in every posting.
Aristotle
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2866233
Not sure if its a "BUG"But since yesterday (April 9) I noticed that when I search for "Renderosity" on Google, the homepage doesn't appear as first result. And its not even in the first 5 or 10.
Maybe there is some problem with the tags / search engine optimization?
Screenshots (with 3 different browsers) in the thread I created (link).
This thread is for actual things that are broken and need to be fixed, so that the powers that be don't have to dig through long threads talking about aesthetics.
NOTE: Don't post your opinions on how the site looks on this thread. That isn't a bug or an issue with site functionality.
