Fri, Jan 31, 5:36 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 3:43 am)
Subject: Poser 7 and Windows 8 will it work
nyguy ( ) posted Wed, 13 March 2013 at 5:52 PM · edited Fri, 31 January 2025 at 5:30 AM
I have a new laptop with windows 8 and thinking of installing Poser 7 on it since I have Poser 8 and Poser 2012 on my main desktop. I don't want to uninstall Poser 2012 or 8 off my desktop because I use them there for testing and figure creation.
Any suggestions?
Poserverse The New Home for NYGUY's Freebies
cedarwolf ( ) posted Wed, 13 March 2013 at 9:39 PM
Can you only install to a single machine now?  Earlier versions didn't have that problem.
LaurieA ( ) posted Wed, 13 March 2013 at 9:42 PM · edited Wed, 13 March 2013 at 9:42 PM
If you can only use one computer at a time then I think it's fine to install whatever you want on the laptop. The only stipulation is that you can't use two instances of the same version at the same time.
hborre ( ) posted Wed, 13 March 2013 at 9:43 PM · edited Wed, 13 March 2013 at 9:48 PM
I see no reason why Win 8 should be a problem.  The only foreseeable issue would UAC interference if application and content are placed into the Programs folder.
BTW, you can use 2 instances of the same program at the same time as long as they do not access the same network.  Poser will detect the network activity; disconnect the computer from the internet and it will work fine.  Otherwise, it will restrict multiple running copies.
nyguy ( ) posted Thu, 14 March 2013 at 6:15 AM
thanks for the advice, I am going to try installing P7 on my Win8 system. I need to use it for testing of stuff I am working on.
