Fri, Jan 10, 11:36 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: Anyone Else Having Problems Running Poser Pro 2012 on Win 8?
onimusha ( ) posted Thu, 14 March 2013 at 9:41 PM · edited Fri, 10 January 2025 at 11:35 PM
Getting a side by side error and installing C++ runtimes hasn't helped.  Does anyone know how to solve this problem.
Why does Windows 8 suck so bad?
AlanaDale ( ) posted Thu, 14 March 2013 at 10:02 PM
Quote - Why does Windows 8 suck so bad?
Maybe they used the same design team responsible for Vista.
ashley9803 ( ) posted Fri, 15 March 2013 at 12:14 AM
The best way with P2012 is to let it install exactly where it wants to. Did you perhaps move away from the default install path/settings? If not, then I really don't know what it could be (and I'll let others iron out the bugs with Win8 before I ever think of moving over.)
infinity10 ( ) posted Fri, 15 March 2013 at 12:29 AM
I'm not having any problems running Poser Pro 2012 64-bit on my Windows 8 64-bit OS.
You may be experiencing a permissions / security issue under your OS. Don't think it is Poser software issue.
Eternal Hobbyist
ashley9803 ( ) posted Fri, 15 March 2013 at 1:28 AM
Quote - You may be experiencing a permissions / security issue under your OS. Don't think it is Poser software issue.
I also think this will untimately be found to be the problem. That's why we installed previous versions outside the program files folder, but I thought with P2012 the issue was corrected. Perhaps not. It's recommended these days to just let it install away happily and there's no problems. That's why I suggested that the OP might have installed to a path that led to permissions/security issues.
FalseBogus ( ) posted Fri, 15 March 2013 at 1:54 AM
win8 64bit and PP2012 working just nicely.
I do install all programs to another drive, other than where windows is (c:) so the restrictions that apply to c:program files doesn't affect. Not that I mind those, but I like to keep my system drive as clean as possible.
onimusha ( ) posted Fri, 15 March 2013 at 2:03 AM · edited Fri, 15 March 2013 at 2:04 AM
I am quite infuriated by this.
When I originally installed PP2012 on my new machine, I had unchecked 32 bit content.  Thinking this was the problem and that it might contain the information I need, I uninstalled and reinstalled PP2012 with this checked.
 I didn't change any install paths, but my next step will be to install onto a separate drive...
PP2012 still doesn't work on my new machine after installing several C++ runtimes and reinstalling.  I'm finding Windows 8 very frustrating.
Thanks for the tips...
FalseBogus ( ) posted Fri, 15 March 2013 at 2:06 AM
I don't have 32bits of poser installed at all so I can confirm that it works without them.
onimusha ( ) posted Fri, 15 March 2013 at 2:12 AM
... and installing to another drive besides C: hasn't worked...
Subsequent installs also haven't asked me for my serial number which makes me think the uninstall hasn't completely removed everything from the HD...
... even more infuriated now...
onimusha ( ) posted Fri, 15 March 2013 at 2:15 AM
32 bit version is working fine, however... wondering if I should just not worry about using the 64 bit version.  How much performance will I lose?
FalseBogus ( ) posted Fri, 15 March 2013 at 2:15 AM
Serial info can be also stored in registry, have you run the install as admin? (I think it might force you to, so might be a dumb question from me)
FalseBogus ( ) posted Fri, 15 March 2013 at 2:16 AM
Quote - 32 bit version is working fine, however... wondering if I should just not worry about using the 64 bit version.  How much performance will I lose?
Not performance but ability to use more than 2Gb of memory for Poser.
ashley9803 ( ) posted Fri, 15 March 2013 at 3:07 AM
"Not performance but ability to use more than 2Gb of memory for Poser"
That's a real performance issue in my book. The ability to access >4 GB of RAM is what P2012 all about. If you don't have that you have one hand tied behind you back with no good reason.
FalseBogus ( ) posted Fri, 15 March 2013 at 3:10 AM
Depends on how you define performance.
But I don't think you're wrong either ;)
onimusha ( ) posted Fri, 15 March 2013 at 3:24 AM
Yeah this is going to be really frustrating... I might try posting this problem on the tech forum and see if someone with a really deep skillset has an answer.  Thanks for all the help...
Teyon ( ) posted Fri, 15 March 2013 at 3:43 AM
You could also, you know, contact Tech Support. Just putting that out there.
ashley9803 ( ) posted Fri, 15 March 2013 at 3:51 AM
Might be time to roll back to Win7 64 rather than the shaddow-boxing with Win8 problems. Yeh, I know this involves the hassle re-installing a new OS. Depends on how much you want to continue fighting. Others have things working fine on Win8, you decide.
Teyon ( ) posted Fri, 15 March 2013 at 4:51 AM
Seriously, I can not stress enough - contact Tech Support. You should not have to reinstall your entire OS for whatever issue you're having with Poser.
onimusha ( ) posted Fri, 15 March 2013 at 8:53 AM
Yeah there's been no response on the tech forum which is probably why it's so sparse.  Tech support here I come...
MistyLaraCarrara ( ) posted Fri, 15 March 2013 at 10:16 AM
the more tech support knows about poser and win8 issues, the more stable the next poser version will be, i imagine.
