Mon, Dec 23, 2:07 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
Subject: Is possible to use the same textures in M4 V4 and K4?
aldebaran40 ( ) posted Sat, 16 March 2013 at 1:45 PM · edited Mon, 23 December 2024 at 1:52 AM
I have saved many textures in my library of materials for V4 , for  M4 and K4 models, I would like able to use them all in all models of GEN4 (example:one V4 UV texture saved , use in K4 model etc etc etc )
I know there scrip to change genesis UV in M4 V4 K4 UV  (but not use genesis), my question is:
Is there some script that change the UV between GEN4   models,   so I can use my textures regardless of the model (always GEN4 models)
Thanks in advance
MistyLaraCarrara ( ) posted Sat, 16 March 2013 at 2:04 PM · edited Sat, 16 March 2013 at 2:06 PM
it's possible to use uvmapper classic to import v4 uvs to m4 and vice versa.  you need to save it as a seperate obj.  i set up a V4muvs cr2. and M4vuvs.
there was a tutorial on how to do it, on which checkboxes to use in uvmapper.
-don't have the bookmark handy.
i tried it with K4.  it stretches m4 and v4 textures, doesn't look so great.
ashley9803 ( ) posted Sat, 16 March 2013 at 2:14 PM
You could get this utility -
UTC2
You'll need to get the right Plugins for the figures.
I have it and it workes a dream, although sometimes you need to tweek the eyebrows in a 2D image program.
WandW ( ) posted Sat, 16 March 2013 at 3:42 PM · edited Sat, 16 March 2013 at 3:45 PM
aldebaran40 ( ) posted Sat, 16 March 2013 at 8:43 PM · edited Sat, 16 March 2013 at 8:50 PM
Ok first at all Than you to all replies .
I already knew The UVmapper and texture convertor way , the problem with these solutions is that I need to convert all the textures, bump, speculars etc ... one by one  , Which would take me a long time,.
"Kids-4-M4V4Textures-Remap" is a partial solution because it works only with models K4 (I also probe)
what I'm looking for is something (free or paid) that basically allows the model used to tell this UV and textures and then charge stored in the library of materials (such as work load textures in DAZ), imagine if in DAZ can be done, it should not be impossible to write a script for Poser that works similarly
I thought if there is already a script that changes the UV of Genesis in Poser  to V4 M4 and K4, I thought that also exist one that changed the UV only between GEN4 models
estherau ( ) posted Sun, 17 March 2013 at 4:47 AM
Oh I think I understand what you are after. Unfortunately I don' think anything like that exists.  It would be great if it did though.
MY ONLINE COMIC IS NOW LIVE
aldebaran40 ( ) posted Sun, 17 March 2013 at 10:25 AM
Yes,  I've been testing a model thatallows swich morphs several GEN4 models and find very interesting the possibility to use all I have of GEN4 morphs together, although not all works perfectly morphs seems like a good option and if someone would develop that idea ,  would have on me a buyer (perhaps the color curvature script was is a good option)
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2864044&page=2
estherau ( ) posted Sun, 17 March 2013 at 6:36 PM
let me know if you get that morph switiching thing working.
aldebaran40 ( ) posted Tue, 19 March 2013 at 11:44 AM
Quote - let me know if you get that morph switiching thing working.
Ok ,If I get something that works Ibe forewarned
ps.if anyone is interested I am testing this character:
http://www.sharecg.com/v/45885/view/Poser/Mix-K4M4V4-morphs
Bejaymac ( ) posted Wed, 20 March 2013 at 10:40 AM
As far as morphs go DAZ did most of the the hard work for you, the EXP system they used for the Gen 4's makes it easier to add channels to a figure, getting the channels from one Gen4 into another just requires you to know which files to copy over, running the correct updater and then loading the 1.2 MB CR2 that DAZ supplied for the figure, the readscript lines in it will do the rest.
The attached pic is a screen shot from DS4.5, it shows I have V4 in the scene (left side) and that I also have Freak 4's morphs in her (right side), as you can see from the textures she's wearing (and yes those are hairy breasts) swapping UV's in DS is childs play, with Poser you have quite a few hoops to jump through.
aldebaran40 ( ) posted Wed, 20 March 2013 at 1:01 PM · edited Wed, 20 March 2013 at 1:02 PM
Thanks for the reply  Bejaymac , but I 'm a Poser user and  I need make this in Poser ,that is why my question was directed to see if there was a script that does what you say,  but in poser,  no in daz
