Photography F.A.Q (Last Updated: 2025 Feb 03 6:38 am)
Interesting video - the Sally/Anne effect was something I wasn't aware of. To further complicate the issue of color perception when dealing with photos viewed on a computer monitor, you never know what kind of monitor your photo will be viewed on or how that monitor might have been adjusted or calibrated, all of which can drastically affect how an image looks. And images look very different on Macs & PCs as well. So when we post our photographic "masterpieces" & they appear to be underappreciated, we can just assume it's either a color perception or monitor calibration problem & feel better about ourselves, right?
Well worth watching! When we tweak the color balance of a photo we may be doing two different things. We could be trying to make it look exactly as we remembered the scene, or we could be trying to make the colors look 'better' to ourselves. This may be viewed by another as very different events with different outcomes in their experience department.
"Art is in the eye of the beholder"
I thought of that phrase when reading this.
What is a friend? A single soul dwelling in two bodies. -
Aristotle
Glass Eye Photography =- -= My Rendo Gallery =-
When this place sorts out the colour issues that are WAY off, we can all then chew the fat over colour. Nearly every image I post the colour is way off kilter. Then you have to constantly remind people to "Zoom for the correct colour" And sharpness for that matter. I know my photography is correcly white ballanced! But it isn't when displayed at this site.
Ronnie - I'm puzzled as to why an image displayed on Renderosity would look differently than the original that was uploaded. The size & number of bytes are identical & I can't imagine that Renderosity would be making any changes to uploaded images. But I can confirm that when I view my original images the colors are somewhat different. Could it be that browser software uses a different JPG display algorythm than the operating system (Windows 7 with the Picasa image viewer in my case)? I've checked with both Firefox, my usual browser, & IE & they both display the image identically. Are you suggesting that Renderosity uses it's own proprietary JPG display algorythm that overrides what the browser uses? Are you posting your photos to another site that displays the images differently than Renderosity?
Ronoir: I checked out your some of your uploads and a few are in colourspace AdobeRGB. That is probably the problem with your colours. Browsers don't handle colourprofiles very well if I remember correctly. Try converting to sRGB before you upload a photo.
When rendo generates a thumbnail the colours can be off because the PHP/GD software doesn't understand AdobeRGB and just messes up the colours.
Aristotle
Hmm interesting as I have always used sRGB my monitor and colour profiles are all set for sRGB
Where the Adobe 1998 comes from search me? After 15 years in the print as a colour matcher I know 98 is only used for printing, as I never ever print anything and only display to web, I find it interesting that you see 98 profiles on my images? Oh well like I said, this site is getting it wrong somewhere. And I am not suggesting you are wrong 3DGuy, I have also just checked my self and seen 98 profiles on some of my images. How tthey got there is a mystery.
Claude. I am not suggesting anything, the evidence is clearly there, the white balance and colours are wrong, and now it seems they are converting colour profiles too.
Is your camera set to AdobeRGB? Mine is
Aristotle
Here is full exif data from my most recent upload
Exif data
Camera Canon EOS-1D Mark II N
Exposure 0.003 sec (1/400)
Aperture f/7.1
Focal Length 280 mm
ISO Speed 400
Exposure Bias +2/3 EV
Flash Off, Did not fire
Image Width 1000
Image Height 689
Bits Per Sample 8 8 8
Photometric Interpretation RGB
Orientation Horizontal (normal)
Samples Per Pixel 3
X-Resolution 240 dpi
Y-Resolution 240 dpi
Software Adobe Photoshop CS6 (Windows)
Date and Time (Modified) 2013:03:20 20:35:25
Exposure Program Aperture priority
Date and Time (Original) 2013:03:20 13:06:05
Date and Time (Digitized) 2013:03:20 13:06:05
Max Aperture Value 5.7
Metering Mode Multi-segment
Color Space sRGB
Focal Plane X-Resolution 3098.143236 dpi
Focal Plane Y-Resolution 3098.143236 dpi
Custom Rendered Normal
Exposure Mode Auto
White Balance Custom
Scene Capture Type Faithful
Serial Number xxxxxx
Lens Info 98-280mm f/5.6+1.4x
Lens Model EF70-200mm f/4L USM +1.4x
Compression JPEG (old-style)
Coded Character Set UTF8
Date Created 2013:03:20
Time Created 13:06:05+00:00
Global Angle 30
Global Altitude 30
Photoshop Quality 10
Photoshop Format Progressive
Progressive Scans 3 Scans
XMPToolkit Adobe XMP Core 5.3-c011 66.145661, 2012/02/06-14:56:27
Format image/jpeg
Lens EF70-200mm f/4L USM +1.4x
Lens ID 187
Image Number 65409
Flash Compensation 0
Owner Name Ronnie James Sefton
Rating 0
Metadata Date 2013:03:20 20:35:25Z
Creator Tool Adobe Photoshop CS6 (Windows)
Legacy IPTCDigest 402BC0F99F3A294C4719340FF557FE79
Color Mode sRGB
ICCProfile Name Adobe RGB (1998)
Document Ancestors xmp.did:A2A28CD97291E211998F972348D914C4
Original Document ID 571537417D3A1A3A3189D0722D2A9FC5
History Action derived
History Parameters converted from image/x-canon-cr2 to image/tiff
History Instance ID xmp.iid:A2A28CD97291E211998F972348D914C4
History When 2013:03:20 15:30:10Z
History Software Agent Adobe Photoshop Camera Raw 7.1 (Windows)
History Changed /
Derived From Original Document ID 571537417D3A1A3A3189D0722D2A9FC5
Color Transform YCbCr
It says:
"ICCProfile Name Adobe RGB (1998)"
11th row from the bottom...
Does cameraRaw make it AdobeRGB by default?
Aristotle
This is where you change the profile in ACR, this is what I had not changed after upgrade. Click the profile hyperlink in ACR marked in red. And choose the ICC profile from the list it is the last one at the bottom. Now your checkmark at save as will be you selected profile. But be aware that if you print directly from within photoshop, you'll need to change this back to 1998. 1966 is for web display 1998 for printing.
Thanks to 3D guys eagle eye :)
Glad you got it sorted out
Aristotle
Hi Ronny,
About opening images in ACR:
I always open my images in the ProPhoto RGB 16 bit colorspace, because that gives me the widest 'color gamut', the widest range of color and tone information to begin with. All my processing is done in ProPhoto RGB 16 bit; it's only after resizing and final sharpening that I change the image mode to 8 bit and convert my images to sRGB, right before saving the images to be displayed for web use.
You should try it, I'm quite sure this will give you the best way to get the best out of your images' colors and tones.
Greetz,
Geert
We do
not see things as they are. ǝɹɐ ǝʍ sɐ sƃuıɥʇ ǝǝs
ǝʍ
Attached Link: Color Perception and How it Might Apply to Photography
This is a good artcle on color perception in photography. I like the point that:"In trying to delineate what is good and what is bad in photography, we should take into account the other person’s perception, but we can’t, even though it could make all the difference."
Some people say a photograph is overworked, or the color is too vibrant and blown out, however, it is only one view point and not necessarily everyone's viewpoint. And, certainly, the artist who presented the finished product as he saw it, sees it in another way.
Flannel Knight's Photos
MrsLubner
Forum Moderator
______________________
"It please me to take amateur photographs of my garden,
and it pleases my garden to make my photographs look
professional."
Robert Brault
