Tue, Nov 26, 8:19 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: Magnum gun seems to attach itself to a figure
art4me ( ) posted Thu, 21 March 2013 at 12:15 AM · edited Fri, 22 November 2024 at 7:18 PM
Hi,
First many thanks for your help on my previous queries to date.
I am using Poser 2010, Windows 7 , amateur user.
My problem is that when I add a gun into a scene such as the Magnum gun it seems to attach itself to a figure in that scene. So when I move the figure it also moves the gun.
It even attached itself to a rat figure and when I deleted the rat the gun went also.
This happens with the revolver prop also so seems common to guns.
I feel it is connected with the gun being able to parent to M3, H3 or A3 hand, maybe this is why.
I tried to change parent but it is the same.
How to I arrange it so the gun is just another stand alone prop not connected to anything.
Oh and if I could on other short question.
Poser is good for internal scenes, I want to do some externals scenes.
What other program do you recommend that is most compatable with Poser that does external scenes, to import figures etc.
I have heard Vue mentioned.
Thanks in advance
ashley9803 ( ) posted Thu, 21 March 2013 at 1:06 AM
Select the gun and go to OBJECT/Change Parent then select Universe (at top of dropdown menu). It should then be un-parented. You can then move it and parent it using the same menu.
Poser now does very good outdoor scenes - look down a few posts for outdoor lighting advise.
FreeBass ( ) posted Tue, 26 March 2013 at 9:23 PM
Ashley is correct IF the gun is a prop (i.e; found in the Props library).
If, however, the gun is a Figure (found in the Character lbrary), ya gotta go to Figure> Conform To> None
WARNING!
This user has been known to swear. A LOT!
hborre ( ) posted Tue, 26 March 2013 at 10:44 PM
Except that if the gun is figure it will not auto conform, it will assume it's zeroed position.
FreeBass ( ) posted Wed, 27 March 2013 at 12:56 AM
Good point... I'm gettin' too used to drag/ drop from the Library in P12 (in which case it can auto conform).
WARNING!
art4me ( ) posted Wed, 27 March 2013 at 2:22 AM
hi
Thanks for the good advice
appreciated
