Wed, Nov 20, 5:47 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 4:32 am)
Subject: Going For Photorealism
Steeleyes101 ( ) posted Wed, 27 March 2013 at 9:13 AM · edited Wed, 20 November 2024 at 5:47 AM
Attached you see two pieces I’m working on that will part of a series of renders that will feature extreme close-up’s.
My problem is I want the skin to look as close to photo realistic images as possible; so I was wondering if someone could give me a few lighting and rendering tips as to how I might best achieve my goal.
Thanks much
Steel
jfbeute ( ) posted Wed, 27 March 2013 at 10:27 AM
Probably your best bet would be to wait for Reality 3.
foxylady1 ( ) posted Wed, 27 March 2013 at 10:49 AM
Did you try this
http://snarlygribbly.org/3d/forum/viewforum.php?f=27&sid=96dcef5468de4d9364b41738eb010b77
It is a great script and I am guessing that you use P9 or PP2012
mgtcs ( ) posted Wed, 27 March 2013 at 11:39 AM
I think you should use IDL lighting Elliot!
Monica
hborre ( ) posted Wed, 27 March 2013 at 11:45 AM
What you really need is a good bump mapping for all the skin textures.  The surfaces are too smooth and imperfection free.  And you are missing quite a bit of ambient occlusion around close proximity surfaces, for example, between the ring and finger.
Steeleyes101 ( ) posted Wed, 27 March 2013 at 12:06 PM
Hborre not sure Im undestanding "bump mapping"  could you direct me to some place where I can get exampls and tutorails
Also "ambient occlusion"
where can I learn more
LaurieA ( ) posted Wed, 27 March 2013 at 1:38 PM · edited Wed, 27 March 2013 at 1:39 PM
I use point lights for lights w/inverse square falloff. Looks better IMVHO :) I also render inside an invisible box. I have it turned off in camera but it's still a light emitter so it will bounce the light around.
Photopium ( ) posted Wed, 27 March 2013 at 1:52 PM
Turn off texture filtering in the material settings, that's a start.  IDL is another.  A Better texmap is still another.
MistyLaraCarrara ( ) posted Wed, 27 March 2013 at 2:45 PM
Quote - I use point lights for lights w/inverse square falloff. Looks better IMVHO :) I also render inside an invisible box. I have it turned off in camera but it's still a light emitter so it will bounce the light around.
do light emitters work without IDL turned on?
LaurieA ( ) posted Wed, 27 March 2013 at 2:48 PM · edited Wed, 27 March 2013 at 2:48 PM
Quote - > Quote - I use point lights for lights w/inverse square falloff. Looks better IMVHO :) I also render inside an invisible box. I have it turned off in camera but it's still a light emitter so it will bounce the light around.
I'm not certain, but I think not. No IDL, no light bounce. I was also talking the light emitter checkbox on an object, not a glowing material. In order for an object to bounce light, the "light emitter" checkbox needs to be checked.
hborre ( ) posted Wed, 27 March 2013 at 2:55 PM
A bump map is similar to a displacement map but it does not have the same impact on the mesh.  Displacement maps can distort and change the mesh.  The Poser Manual does explain the difference between the two.
Smith-Micro does have a tutorial/explanation on ambient occlusion, but, in a nutshell, ambient occlusion occur in areas where surfaces are in close contact creating realistic shadows in inner corners, crevices and crannies.  You can either add ambient occlusion through lights or material based nodes.  And it can be evaluated in IDL.
