Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
I got Inagoni plug-in Deeper for Carrara 7.2 Pro. I cannot get Deeper to work at all. The instructions on the Inagoni page for using Deeper don't work. I put a jpeg image in the Color sub-shader and a normal map into the bump map sub-shader under the Deeper shader. The texture from the normal map doesn't display at all. I don't know if I have set up the shader correctly.
