Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
That's an interesting idea. There are two different types of problem.
(1) A script that is only available in a compiled .PYC form can't be converted at all; it has to be rewritten by its author and then recompiled.
(2) A script that's written in .PY form (readable text) typically needs only a couple of predictable changes that I know of.
col=
needs to be changed to
column=
and
raise "some message"
needs to become
raise Exception("some message").
There are other differences between versions, but those are the ones that come up most often here.
I'll try writing a batch converter for those changes. I've got quite a few scripts with the raise Exception() problem, so I can test it and solve my own problem at the same time.
My python page
My ShareCG freebies
The pyc format is compiled, allowing distribution of a script in a form that can't be read/modified/swiped by the end user. Some people like them.
Another big update issue is Numeric to Numpy conversion. Generally, one can fix any issues in that area with a few simple, predictable tricks that might be scriptable. Sometimes there's a more complex problem which may require human thought. :unsure:
Tk for the current Poser Python also has a bug in askopenfilenames, which has required that I update a few scripts.
ok, i know this should be in the python forum,and i will be posting this there too. My question to all you python gurus is, can someone make a python script that can take an older python script and update it so it then works with poser 2012? i have too many scripts that force me to fire up older versions of poser just to run them. very annoying, surely a script can be made to update other ones.
Getting old and still making "art" without soiling myself, now that's success.
