Fri, Jan 10, 12:44 AM CST
Subject: Bryce7 Pro to Daz 3
caty77 ( ) posted Tue, 02 April 2013 at 8:16 AM · edited Thu, 09 January 2025 at 5:31 PM
Hello,
I just ask you for information between Bryce and Daz, because I mess a little (sorry for my English).
I'm trying to create a home in Bryce, for import into Daz. For objects that must remain fixed, no problem. However, the doors look too far on the x and z axes.
I tried to save them in Daz by coupling them to a cube (one by one), but loading the object containing the cube + the door, order again soon. And all doors cannot remain at 0.
Does anyone have a solution to offer? Thank you in advance.
UVDan ( ) posted Fri, 05 April 2013 at 12:30 AM
Forum Moderator
Just scale them in DS.
caty77 ( ) posted Fri, 05 April 2013 at 2:53 AM
Hello.
It is already at the desired scale for Daz. Unfortunately, the doors continue to run around others axes, and not where I want.
caty77 ( ) posted Fri, 05 April 2013 at 4:56 AM
I must say that I tried importing to a custom size. Then I recorded the door in Export. The door goes wrong when I re-import it.
Then I tried importing the door to Bryce size (over 24 000%). Then I cut the door to save by Export. The door goes wrong too.
UVDan ( ) posted Fri, 05 April 2013 at 8:26 AM
Forum Moderator
I think you are going to have to use the figure setup tools to re orient the axes on the door.  There is a thread in the DAZStudio forum at DAZ about resetting the rotate point.  It was recent so it should not be too hard to find.
caty77 ( ) posted Fri, 05 April 2013 at 9:54 AM
Thank you.
Are you talking about this subject?
http://www.daz3d.com/forums/viewthread/8322/
No, I have to say here does not help me at all.
DS3 and I found absolutely no place where I could choose Settings Tool.
And I prefer to work in DS3, because DS4 bugs regularly.
As a bonus, I've changed the numbers of the axes of rotation, and the door that serves as my test ride in all directions but never to the desired location.
caty77 ( ) posted Mon, 08 April 2013 at 11:16 AM · edited Mon, 08 April 2013 at 11:20 AM
Finally, I looked differently. That is to say, how to create a file .pp2.   :)))
And doors seem to work while standing still.
For those interested, you should go on this topic
 http://forumarchive.daz3d.com/viewtopic.php?t=127437
So that the door remains in place, I added a square which I related the door (the square should be in the door hinge side).
UVDan ( ) posted Mon, 08 April 2013 at 1:10 PM
Forum Moderator
Glad to hear it.
