Tue, Jan 7, 3:26 PM CST
Subject: Trouble with transperencies.....
CarolineG ( ) posted Mon, 17 September 2001 at 12:37 PM · edited Tue, 07 January 2025 at 3:07 PM
Could somebody please help me out.. I bought the SW lingerie of Sara Wendy Olivera And I cannot get the transmaps to work on the bikinibottom... If I do what she says in the readme the bottom is invisible.... The top works bot the bottom is giving me a headage!!!! I'm usually pretty good with transmaps but this time I suck.. Please help and any help much appreciated *S* Caro
haria ( ) posted Mon, 17 September 2001 at 1:05 PM
Attached Link: http://http://www.renderosity.com/viewed.ez?galleryid=82865&Start=1&Artist=haria&ByArtist=Yes
Caro, I may be able to assist I too bought SW Lingerie from Sara Wendy Olivera. Mine work, what you do is that in the material panel select the object the bikini bottoms in the material tab select bottom then change to object to a desired colour. In the Texture Map panel select the desired lingerie bottom. Increase the Transparency bar to maximum and select the the same lingerie bottom as in the Texture Map bottom. Finally click OK and hey presto!!! like this image !!
CarolineG ( ) posted Mon, 17 September 2001 at 1:36 PM
I tried that Haria, and it is still invisible.....:( Look at the image of the material editor, maybe you can see what I'm doing wrong... The image looks great *S* Thanks for the help! Caro
haria ( ) posted Mon, 17 September 2001 at 1:45 PM
Just sent you an IM message: Reduce the Transparency Min to zero then it will work!! ;)
CarolineG ( ) posted Mon, 17 September 2001 at 2:00 PM
I did that, and it still is invisible...... I don't know what to do anymore.... Caro
Poppi ( ) posted Mon, 17 September 2001 at 3:02 PM
If there are more than one texturs for this set, there may be transmap, a, b, c, or some such. Go in and check...if there are more than one trans for the bikini, try changing them.
CarolineG ( ) posted Mon, 17 September 2001 at 4:33 PM
I tried all 6 of them, not one works, reinstalled the clothing pack already too didn't help either... Even with detailed instructions of Wendy herself it doesn't work..... It is driving me nuts..... Caro
Wadus ( ) posted Mon, 17 September 2001 at 4:52 PM
maybe its because the trans map is loaded as the texture also??
Poppi ( ) posted Mon, 17 September 2001 at 5:08 PM
Wadus...looks like you got it. I bet that is what it is....Oh, my...didn't even see that, just the number. ;)
CarolineG ( ) posted Mon, 17 September 2001 at 5:18 PM
No sorry even without it loaded as the texture it doesn't work, I tried it like that because Haria said it worked for him that way..... Something is totally screwed with this bikini bottom and I could eat it!!!!!!!!!
Poppi ( ) posted Mon, 17 September 2001 at 5:36 PM
You know what might help? Open Photoshop, or whatever you use...and look at the texture and trans map. Maybe something is labelled wrong. (I've done that myself, so it can happen.)
CarolineG ( ) posted Mon, 17 September 2001 at 6:29 PM
Ok guys and girls, figured it out..... My obj of the bikini bottom was corrupt!!!!!!!!! So it wasn't the transmap or me goig nuts hehe Here is a render to prove *S* Thanks all for the help, Caro
Poppi ( ) posted Mon, 17 September 2001 at 7:33 PM
LOL...that's a hot lil outfit, too. Congrats. Amazing how time just gets wasted ain't it. :*)
haria ( ) posted Tue, 18 September 2001 at 1:04 AM
Caro, So it was a bikini bottom that was corrupt that explains the problem you had. Anyway it looks good now!
