Attached Link: http://http://www.renderosity.com/viewed.ez?galleryid=82865&Start=1&Artist=haria&ByArtist=Yes
Caro, I may be able to assist I too bought SW Lingerie from Sara Wendy Olivera. Mine work, what you do is that in the material panel select the object the bikini bottoms in the material tab select bottom then change to object to a desired colour. In the Texture Map panel select the desired lingerie bottom. Increase the Transparency bar to maximum and select the the same lingerie bottom as in the Texture Map bottom. Finally click OK and hey presto!!! like this image !!This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
![file_211348.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_211348.jpg)
Could somebody please help me out.. I bought the SW lingerie of Sara Wendy Olivera And I cannot get the transmaps to work on the bikinibottom... If I do what she says in the readme the bottom is invisible.... The top works bot the bottom is giving me a headage!!!! I'm usually pretty good with transmaps but this time I suck.. Please help and any help much appreciated *S* Caro
