Sat, Sep 21, 9:36 PM CDT
Vue F.A.Q (Last Updated: 2024 Sep 20 5:40 am)
Subject: Volumetric strangeness?
zoon ( ) posted Mon, 17 September 2001 at 12:11 PM · edited Sat, 21 September 2024 at 9:31 PM
Here is a message I have just sent to e-on: "I made a volumetric atmosphere, had the sun in the frame, and placed a test object in its path. I got volumetric shadows. The problem is, I have rendered this simple scene with volumetric intensity for the sun set to 0.1, and set to 10, and I can find absolutely no difference in the two images. I've done lots of set-ups, and every pair I render, the volumetric intensity setting seems to have no effect. When I take the sun out of the frame, and put a new directional light in the frame, I can't get ANY volumetric shadows from this light. Spots and point lights work perfectly. Am I not understanding something - maybe. I went to check this on my work machine which still has 4.00 on it, and found the same thing, and also on my laptop running 4.02." Anyone tried this - spot lights give a vast change when I alter the volumetric intensity, but the sun gives no change, and directional lights give nothing.
Kurka ( ) posted Mon, 17 September 2001 at 1:06 PM
Same here,- Fernando.
Cheers ( ) posted Mon, 17 September 2001 at 2:00 PM
Try changing the shadow intensity beyond 100%..you will find that the shadows cast will be more noticable then. Hope that helps, Cheers
Twitter: Follow @the3dscene
Cheers ( ) posted Mon, 17 September 2001 at 2:04 PM
Sorry...forgot to post the image. Cheers
gebe ( ) posted Mon, 17 September 2001 at 2:15 PM
Same for me, Adrian. I have told this already to Nicholas when we was at end beta and again when Vue 4 just came out and I did what Cheers is mentioning above. Nicholas told me that it is a nonsense to bring up shadow to 200, 300 (or even more) and out of any logic. Normally I agree, but technically there seems no other way to get it. Guitta
zoon ( ) posted Wed, 19 September 2001 at 12:14 PM
I'm glad its not just me. I take the point about typing in values above 100, this works for many Vue functions, but what do we do if we want to reduce the intensity?
gebe ( ) posted Wed, 19 September 2001 at 12:56 PM
You mean redouce shadows ?
gebe ( ) posted Wed, 19 September 2001 at 12:59 PM
or intensity of the sun ?
zoon ( ) posted Wed, 19 September 2001 at 1:05 PM
I mean reduce intensity of the shadows. I found that 0.1 was exactly the same as 100. Ho hum.
Cheers ( ) posted Wed, 19 September 2001 at 2:08 PM
If you mean the intensity of the shadows that fall on objects, then the best way is to start your scenes (any scenes in any software) with 0% Ambience assigned to the materials of all objects, and in Vue also set the light balance to 100% in the Light tab of the Atmosphere Editor (this setting option will control shadow darkness). The strength of shadows should always be adjusted with fill-in lights for greater or more realistic control...unless you have access to radiosity within the software. Cheers
zoon ( ) posted Thu, 20 September 2001 at 12:32 PM
Thanks cheers, but that's not what I'm looking at. The 'problem' is the shadows cast in the air in a volumetric atmosphere. Here is a pic with vol intensity set to 100. The next message contains the same pic set to 0.1. Can you spot the difference?
zoon ( ) posted Thu, 20 September 2001 at 12:33 PM
here is the pic with volumetric intensity set to 0.1
Cheers ( ) posted Thu, 20 September 2001 at 12:50 PM
Okay zoon, Looks like you have a bug there. There does seem to be little point in having settings that don't work below 100%. The only other suggestion I can come up with is to turn down the haze and/or fog in the atmosphere editor, to lessen the contrast. Obviously that may have other less desirable effects elsewhere in your render :( Cheers
