Sun, Feb 2, 12:04 PM CST
Forum Moderators: Staff
Subject: Morph injecting at 2.0?
Darkworld ( ) posted Mon, 08 April 2013 at 9:56 AM · edited Sun, 02 February 2025 at 11:53 AM
So i have a problem with a package where if you use an INJ then REM, then INJ again it is injected at 2.0 strength.
Anyone know if there is a way to add a limit of 1.0 to a morph INJ Pz2?
fly028 ( ) posted Mon, 08 April 2013 at 10:29 AM
Hello,
If you edit in a text editor your inj_Pz2, you will see that max is certainly set at 1. Just modify the max limit for each part impacted.
If you don't want to modify your file:
In poser, just at the right of the dial, there is arrow, right click on it/ settings/ and set max at 2 or more. Should work now,
Hope it helps
Darkworld ( ) posted Mon, 08 April 2013 at 12:50 PM
that fixed it.  There was no min or max in the pz2 but I was able to add it manually :)
