Forum Moderators: Staff
Hello,
If you edit in a text editor your inj_Pz2, you will see that max is certainly set at 1. Just modify the max limit for each part impacted.
If you don't want to modify your file:
In poser, just at the right of the dial, there is arrow, right click on it/ settings/ and set max at 2 or more. Should work now,
Hope it helps
So i have a problem with a package where if you use an INJ then REM, then INJ again it is injected at 2.0 strength.
Anyone know if there is a way to add a limit of 1.0 to a morph INJ Pz2?
