Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Sure. It's easy. I BELIEVE 9 will do it... I know Pro does.
Load and cfonform the clothing item.
Select the Body of the item.
Go to the "Properties" Window of the Parameter control.
Check the four check boxes you will see there:
"Include Morphs when Conforming"
"Include Scales when Conforming"
"Match Endpoints when conforming"
"Follow origins when conforming"
The item will now track all changes made to the figure.
(If I'm wrong about this working in Poser 9, someone correct me, please.)
I have a script that will set all 4 in p9+ for a clothing item. Unfortunatly, P8 did not have the python methods to do the same. It also adjusts scaleing back to 1.00 in case you have scaled it seperatly.
Unless you do what I do and doc your python pallet and have it loaded. It probably faster to just click on the boxes.
Biill
For the Marketplace = can you make a search option possible for Crosstalk clothing
So we know which products (clothes) are using Cross talk technique
Thanks
