Sun, Oct 6, 9:20 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Subject: request for RenderoSity. Crosstalk
efron_241 ( ) posted Tue, 16 April 2013 at 9:35 AM · edited Sun, 06 October 2024 at 7:39 AM
For the Marketplace = can you make a search option possible for Crosstalk clothing
So we know which products (clothes) are using Cross talk technique
Thanks
basicwiz ( ) posted Tue, 16 April 2013 at 11:25 AM
What version of Poser are you using? If you have 9 or Pro you can activate this for ALL clothing.
efron_241 ( ) posted Tue, 16 April 2013 at 11:29 AM
huh... How ?
basicwiz ( ) posted Tue, 16 April 2013 at 11:53 AM · edited Tue, 16 April 2013 at 11:54 AM
Sure. It's easy. I BELIEVE 9 will do it... I know Pro does.
Load and cfonform the clothing item.
Select the Body of the item.
Go to the "Properties" Window of the Parameter control.
Check the four check boxes you will see there:
"Include Morphs when Conforming"
"Include Scales when Conforming"
"Match Endpoints when conforming"
"Follow origins when conforming"
The item will now track all changes made to the figure.
(If I'm wrong about this working in Poser 9, someone correct me, please.)
efron_241 ( ) posted Tue, 16 April 2013 at 12:10 PM
I will try and let you know
 thanks
cedarwolf ( ) posted Tue, 16 April 2013 at 1:15 PM
Interesting.
willyb53 ( ) posted Tue, 16 April 2013 at 3:49 PM
I have a script that will set all 4 in p9+ for a clothing item.  Unfortunatly, P8 did not have the python methods to do the same.  It also adjusts scaleing back to 1.00 in case you have scaled it seperatly.
Unless you do what I do and doc your python pallet and have it loaded.  It probably faster to just click on the boxes.
Biill
efron_241 ( ) posted Wed, 17 April 2013 at 1:00 AM
Tried it with some clothes
and yes. some elements work indeed
Thanks
