Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 8:53 pm)
Quote - After looking thru endless .pz3 files trying to determine which is the one I want to order I realized there must be a .pz3 viewer that lets me see an image of the file.
Isn't there? If so, which one do you recommend?
Where are these files located that you are looking through? I've never run across a site that posts PZ3's for download that would call for this sort of utility.
Sigh....Bryce used to always save a BMP of the current scene when saving said scene. Really wish Poser would do it too!
My
self-build system - Vista 64 on a Kingston 240GB SSD,
Asus P5Q
Pro MB, Quad
6600 CPU, 8 Gb Geil Black Dragon Ram, CoolerMaster HAF932 full
tower chassis, EVGA Geforce GTX 750Ti Superclocked 2 Gb,
Coolermaster V8 CPU aircooler, Enermax 600W Modular PSU, 240Gb SSD,
2Tb HDD storage, 28" LCD monitor, and more red LEDs than a grown
man really
needs.....I built it in 2008 and can't afford a new one,
yet.....!
My
Software - Poser Pro 2012, Photoshop, Bryce 6 and
Borderlands......"Catch a
r--i---d-----e-----!"
It says that P3do exporer pro's viewer can view .pz3, so it look's like the answer is yes...
see this page... http://www.senosoft.com/p3doproFileFormat.php?soft=pro
Also you might want to look at this script on PhilC's python forum... Apparently a script to render out a .png for a .pz3. I myself never got it to work but I think that was just a formatting error on my part. Might be useful if dashing off a preview render is too tedious.
I have the same problem with hex and i end upsaving a small screendump image of anything i want to keep.
P9 and PP12 has a scene library built into the programme which produces thumbs (just like any other library, so long as you save the scene within the programme to the scene library it will generate a thumb)
If you are inclined to upgrade from time to time then this will eventually solve the problem.
EDIT - Ive just noticed your other post regarding installing p9 error so assume you have just got it , you should be able to from now save as above and see a thumb, the old scenes you can (if you want ) reload but then resave to the scene library so you dont go through all that again at a later date, then delete the old scene file.
Tools:- Win10, Dell XPS8900, ZBrush, Marvelous Designer 11, Hex 2, PSP8. PSP 2019 Ultimate, DAZ Studio, Affinity Photo, Affinity Designer, Filterforge 11, flowscape, Classic UVMapper, and several headache tablets.
this was one of the first things i noticed when i updated,
you can save and delete from here but be warned, in my experience dont delete from here as i can never find it in recycle bin if you did it by mistake, think it chucks it out and bypasses the bin.
if you move your scenes to the scene folder in your runtime they wont show thumbs, not sure if the rsr converter tool will help with the thumbs as there aint any rsr files :/
Any new scene saved from now within the programme will have a thumb
attached is where you save your old files within the runtime
