Sun, Dec 22, 3:54 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 20 7:20 am)
Subject: Poser 9 Screen Keeps Changing...I Can't Get into Library
romangirl ( ) posted Fri, 26 April 2013 at 3:22 PM · edited Sat, 21 December 2024 at 10:51 PM
My Poser 9 window has been jumping around and changing size.  Where the library used to be on the right and (barely) accessible, now it has moved to the top, and is so narrow, that if I try to do a search, I can't find anything!  Every time I touch the window, it leaps around and gets bigger.  Any help is appreciated!
ashley9803 ( ) posted Fri, 26 April 2013 at 5:18 PM
Maybe you need to reset to factory state. There was also a thread about fixing GUI issues-
WandW wrote-
"Poser.ini is a file  where Poser stores most of its configuration settings.  If you are using Windows, it's in your folder under c:Users in AppDataRoamingPoser9 (I think that's right).  To see the extension you will need to uncheck Hide Extensions for Known File Types in the folder's View Properties.  Rename it to something like Poser.old.ini after closing Poser and it will generate a new one when it restarts."
dnstuefloten ( ) posted Fri, 26 April 2013 at 6:19 PM
I had the same sort of probem using PP2010. Figured out finally that by moving the parameter group all the way to the right edge of the screen, it docks there. Then I grab another section and dock it elsewhere, all the time swearing under my breath. It seems to finally settle down, but I cant entirely explain how it all works. Just grab and move things, and hope for the best!
Poser Pro 2014
My personal website: Novels, photos, video, sculptures and more
Evidence of a Lost City: An animated movie and novel, in progress
Hag: A novel and live-action movie
romangirl ( ) posted Fri, 26 April 2013 at 6:32 PM
Thank you!
MistyLaraCarrara ( ) posted Sat, 27 April 2013 at 7:39 AM
once you have it arranged, you could save it to the ui dots.
romangirl ( ) posted Sat, 27 April 2013 at 12:27 PM
OK thank you!
