Sun, Jan 26, 7:31 PM CST
Subject: lwo to obj???
DarkEden ( ) posted Tue, 18 September 2001 at 4:25 AM ยท edited Sat, 11 January 2025 at 5:12 PM
How can i convert lwo files to obj is there any program outthere that you could tell me about? //DarkEden
thip ( ) posted Tue, 18 September 2001 at 4:32 AM
www.anim8or.com should do the trick. It's free, it imports lightwave, saves obj's - and remember to write a nice e-mail to the creator of that remarkable app.
cooler ( ) posted Tue, 18 September 2001 at 5:07 AM
it can also be done (& very easily) with the poser pro pack. The lightwave plugin has worked flawlessly for me since day 1. Prior to the ppp I used 3D exploration to convert lwo meshes to a poser useable format. They are now owned by Right hemisphere & you can find all the info about it here... http://www.us.righthemisphere.com/products/3dexplore/index.htm
DarkEden ( ) posted Tue, 18 September 2001 at 5:43 AM
When i try to import lwo files into poser pro pack or poser as i call it couse it's merged together. I get a error message that says that my plugin is broaken and doesn't work. I dunno why i guess it was broken from day 1 i bought it. What shall i do about this?
cooler ( ) posted Tue, 18 September 2001 at 6:22 AM
I've had that error message (I assume is the 'FFLW.arp' message) only with ome type of model... if, in lightwave, I toggle metanurbs on with the tab key & forget to 'freeze' the polygons before exporting poser will get very cranky & refuse to let me import the model.
DarkEden ( ) posted Tue, 18 September 2001 at 7:14 AM
How do you mean freeze? And yes thats the errormessage and it's quite bugging me right now... :)
cooler ( ) posted Tue, 18 September 2001 at 7:25 AM
When you have you mesh in the lightwave modeller to find the 'freeze' tool click on 'Tools' then scroll down the menu... (it's the 2nd last tab) or just hit ctrl+D Bear in mind this is how it works in lightwave 5.6, if you have a different version you may have to hunt around a bit :-)
DarkEden ( ) posted Tue, 18 September 2001 at 8:32 AM
L Ah got it Thanks :)
WarriorDL ( ) posted Tue, 18 September 2001 at 1:13 PM
You can also export to OBJ format right from LW Modeler. Then open the new OBJ file in UVMapper and remap it.
