Fri, Mar 13, 5:03 AM CDT
Renderosity Forums / Freestuff
Welcome to the Freestuff Forum
Forum Moderators: wheatpenny, RedPhantom Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2026 Feb 25 2:04 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all  freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered.  Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Free Stuff Guidelines
Subject: Privy
PrecisionXXX ( ) posted Thu, 09 May 2013 at 2:03 PM · edited Thu, 12 March 2026 at 11:54 AM
http://www.sharecg.com/v/69136/view/11/Poser/Privy
A simple privy from the era of iron men and steam locos, based kinda loosely on railway drawings.  Some displacement maps, Hope I didn't forget something else this time, I'm getting good at that.
Doric
The "I" in Doric is Silent.
LaurieA ( ) posted Thu, 09 May 2013 at 4:36 PM
PrecisionXXX: I make a new runtime for every project I work on and link it to the library. EVERYTHING I do/make/save goes in that Runtime. When I'm all done, it's ready to pack and I rarely forget stuff. LOL. Laurie
PrecisionXXX ( ) posted Thu, 09 May 2013 at 5:38 PM
My problem is I'm usually running all over my computer to get the textures, but forget to move them into the same folder, and when it calls for one of them and can't find it, I don't have to wonder.  Mine will find it, of course. but nobody else will.
Doric
LaurieA ( ) posted Thu, 09 May 2013 at 6:31 PM
Hehehe...can't help ya there ;).
mrsparky ( ) posted Sat, 11 May 2013 at 8:05 PM
nice freebie. BTW to quickly fix path and things - in windows associate CR2 and PP2 files with wordpad then you can easily use the search/replace thingy on the paths.
PrecisionXXX ( ) posted Sat, 11 May 2013 at 10:52 PM
Well, um, if I don't remember to include them in the zip, knowing the path on my computer might be less than usefull.  Most won't even have a Povray folder.
Doric.
PrecisionXXX ( ) posted Sat, 11 May 2013 at 10:59 PM
In playing with it in the material room, darkening it up makes it look better.
D.
mrsparky ( ) posted Sun, 12 May 2013 at 6:32 AM
are you using windows or a mac ?
PrecisionXXX ( ) posted Sun, 12 May 2013 at 9:07 AM
Using windows, but it wouldn't make any difference what system I was using. IF I don't put the files in the zip, they ain't there when someone downloads.  When I'm deciding which one I"m gonna use, I might be using the .bmp, but I've been converting them to .jpg for the zip, at the same time moving that to the correct location.  Sometimes.  Sometimes I make mental notes to do it, then the notes disappear.
Doric.
mrsparky ( ) posted Sun, 12 May 2013 at 11:52 AM
Yea I frequently get wetware data loss as well:) Simple trick here can help. It's kinda the manual version of runtime repair software. Open up the final version of the CR2/PP2, find all the texture names. Paste them into notepad. Minimise everything (Windows Key & M) Next press F3. This will bring up windows search. Paste each name into search, set your search options to where you think they'll be. Once search has finished, right click the file it's found. Copy it (NOT move) to the directory where the final textures for that model will live. Repeat for each texture.
rokket ( ) posted Fri, 24 May 2013 at 10:01 PM
Hehe... this is why I stick to procedurals. Everything is in the mc6 and I don't have to remember to copy the texture files... because I forget more than I remember.
PrecisionXXX ( ) posted Sat, 25 May 2013 at 12:03 AM
I'm also in the process of moving files around, trying to decide what I used and what I didn't.  I'm trying not to let any of the huge bitmaps be moved into the textures, it's too easy to make .png or .jpg and they don't take nearly as much disk space.  It's only in the last few that I've really had to even think about this, and I think reverting to only a couple texture images and the rest procedural where I can is where I'll be going.
(Think, hell.  I know where I'm going)
Doric.
rokket ( ) posted Sat, 25 May 2013 at 1:36 PM · edited Sat, 25 May 2013 at 1:37 PM
Yeah, after I get done with rigging, I am going to tackle learning all the nodes in the material room. I am going to figure out what effect each node has on the render, and then figure out how the math plays into it. I can create some really simple 2,3,4 or 5 node materials that are sufficient, but if I want to be able to do what bagginsbill does, I am going to have to really knuckle down.
After I get Poser Pro 2014 and finally have to deal with gamma correction, things will get interesting.
LaurieA ( ) posted Sun, 26 May 2013 at 2:52 AM
I've been in the material room for nearly two months now...mostly, not a clue. Good luck. LOLOL.
