Fri, Jan 3, 1:12 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 03 1:09 pm)
Subject: Is there an Alyson2 freebie anywhere?
toastie ( ) posted Mon, 13 May 2013 at 7:39 AM · edited Fri, 03 January 2025 at 12:56 PM
Does anyone know of an Alyson2 clothing freebie anywhere for download? I can't find anything here or on ShareCG. I need something that has NO Anastasia morphs so that I can test a conversion idea.
Thanks in advance for any help!
monkeycloud ( ) posted Mon, 13 May 2013 at 7:41 AM
Is there not some Alyson2 clothing in the bundled Poser content?
toastie ( ) posted Mon, 13 May 2013 at 7:44 AM
Quote - Is there not some Alyson2 clothing in the bundled Poser content?
It looks as if there should be a bra and pantie set, but it seems to be missing from my runtime unfortunately!
(Possibly I didn't download all the content as my broadband was borked at the time I bought PP2012)
LaurieA ( ) posted Mon, 13 May 2013 at 7:44 AM
Ya might try EClark's freebies too. He does a lot for the Poser figures and Miki.
toastie ( ) posted Mon, 13 May 2013 at 7:48 AM
Quote - Ya might try EClark's freebies too. He does a lot for the Poser figures and Miki.
Thanks - where would I find them? I looked in the freestuff here, but everything seemed to be for Anastasia, so no good for my experiment.
monkeycloud ( ) posted Mon, 13 May 2013 at 7:57 AM · edited Mon, 13 May 2013 at 7:57 AM
I have a hooded onesie kicking about, that I managed to rig (okay-ish) for Alyson2, modelled and rigged using Lyrra's Alyson2 developer kit as a starting point.
Pretty sure I have retained a version without any attempts made to add Anastasia morphs.
Not yet really finished, but it might serve for an experiment :)
If you're still stuck later, I could send you that... I would hopefully get a chance later tonight to dig it out... as I say, pretty sure I have a version without any Ana morphs added.
I was going to make it a freebie at some point down the line if I ever finish it. Maybe with the new Fitting Room I will! I'll definitely be having a go at fitting it to Rex, Roxie and whoever else myself, come the 21st! :)
You could possibly, quite easily remove the Ana morphs from another freebie piece, for the sake of the experiment? Just make a copy and then delete the applicable morph channels perhaps?
monkeycloud ( ) posted Mon, 13 May 2013 at 7:58 AM
Not in front of Poser till later... so can't check the SM content runtime for any bundled clothing... or its whereabouts...
toastie ( ) posted Mon, 13 May 2013 at 8:04 AM
Thanks, Monkeycloud! That would be great. I just need something to test an idea, so doesn't need to be anything for commercial use - or even anything that's finished! ;)
Just something that isn't going to fit Ana before I start messing about with it.
I was sure there was some clothing for Alyson2 with Poser that I could use. All I seem to have is a bra and pantie set that doesn't actually exist. :(
toastie ( ) posted Mon, 13 May 2013 at 8:12 AM
Quote - Try:-
http://www.sharecg.com/v/63729/view/11/Poser/Alyson2-Tight-Dress
http://www.sharecg.com/v/43954/Poser/Alyson-3-Piece-Outfit
http://www.sharecg.com/v/45575/view/Poser/Alyson-Steampunk-Dress
Thanks for the suggestions, but for what I want it needs to be something made for Alyson2 and conforming, rather than dynamic.
monkeycloud ( ) posted Mon, 13 May 2013 at 8:12 AM · edited Mon, 13 May 2013 at 8:15 AM
Quote - Thanks, Monkeycloud! That would be great. I just need something to test an idea, so doesn't need to be anything for commercial use - or even anything that's finished! ;)
Cool... well, I suspect PhilC's suggestions above will do the trick for you in fact? :)
EDIT: Looks like the second and third are conforming?
EDIT AGAIN: Oh, right... I see, they're just for Alyson?
I'll dig the onesie out in any case, when I can, and send it on, in case it's of use...
toastie ( ) posted Mon, 13 May 2013 at 8:36 AM
Quote - I'll dig the onesie out in any case, when I can, and send it on, in case it's of use...
That's great. Thanks a lot!
PhilC ( ) posted Mon, 13 May 2013 at 8:48 AM
Have you tried using Wardrobe Wizard to convert clothing made for other figures to fit Alyson? Wardrobe Wizard and the Alyson support files are included in Poser.
toastie ( ) posted Mon, 13 May 2013 at 9:41 AM
Quote - Have you tried using Wardrobe Wizard to convert clothing made for other figures to fit Alyson? Wardrobe Wizard and the Alyson support files are included in Poser.
Thanks for the idea, but I really need something made for Alyson2 for this test, rather than converted.
vilters ( ) posted Mon, 13 May 2013 at 10:47 AM · edited Mon, 13 May 2013 at 10:49 AM
Can you give a discription of what exactly you are looking for?
Blouse, shirt, pants, with or without moprhs?
PhilC ( ) posted Mon, 13 May 2013 at 10:58 AM
Not really sure what difference it would make but it is up to you.
toastie ( ) posted Mon, 13 May 2013 at 11:07 AM
Quote - Can you give a discription of what exactly you are looking for?
Any item of clothing made for Alyson2 that doesn't have Anastasia morphs. I just need an item I can use to test a conversion from Alyson2 to Anastasia so anything will do, just to see if it works. I just don't seem to be able to find anything I can use to test.
@PhilC - thing is, I don't know whether using something that's already been converted from another figure might affect my conversion test. I'd rather start with something I know is made for Alyson2, instead of converting something first and then converting it again.
PhilC ( ) posted Mon, 13 May 2013 at 11:18 AM
How would you find out?
toastie ( ) posted Mon, 13 May 2013 at 11:28 AM
Quote - How would you find out?
Well my plan was to try making some improvements to my clothes conversions. (XD is my weapon of choice - nothing against WW, I've just been using XD for years, so it's what I know well). So far all my little improvements seem to be working quite well. I thought I could try and extend my improvements with other figures into converting clothes to Anastasia. To start off with I wanted to try converting just from Alyson2 to Anastasia to see if that worked. Then move on to converting already converted clothing. I don't know if it would make all that much difference. I just want to try it as a baseline to see how well it works - if at all. Only I discovered I don't actually have any clothing made for Alyson2 and I can't find any freebies to try as they all seem to already have Ana's morphs. It's really not a big deal, I just thought someone might know where I could find something I could use.
I do appreciate your help and suggestions. It's just not really what I'm after right at the moment, that's all.
bwldrd ( ) posted Mon, 13 May 2013 at 4:05 PM
Hmm... well in case you may have forgotten, you know alyson2's clothing is in the under props and not characters in the library, yes?
Consider me insane if you wish, but is your reality any better?
toastie ( ) posted Mon, 13 May 2013 at 7:26 PM
Quote - Hmm... well in case you may have forgotten, you know alyson2's clothing is in the under props and not characters in the library, yes?
Yup, thanks. But I don't seem to have it. I suspect I never downloaded it.
RedPhantom ( ) posted Mon, 13 May 2013 at 7:48 PM
Site Admin
Couldn't you download it now?
meatSim ( ) posted Mon, 13 May 2013 at 8:27 PM
I dont have poser open right now.. but I think some of allison2s included clothing is in the props folder even though they are figures... they are also possibly lumped in with allisons clothing just to make it more difficult...
I think there is one allison 2 cr2 that loads with bra panty and hair already on.
disclaimer operating from vague memory here the preceding statements may or may not be true
toastie ( ) posted Mon, 13 May 2013 at 8:46 PM
@RedPhantom - are they downloadable from somewhere?
@meatSim - The "clothed" version of Alyson2 doesn't have the clothes either. Poser can't find them. I think I just never downloaded the clothing files as my broadband wasn't working properly at the time.
NanetteTredoux ( ) posted Tue, 14 May 2013 at 11:58 AM
I just checked my runtimes too - Alyson2 has very little bundled clothing specifically for her. I found just just the bra and panties. I bought physical copies of Poser until now, so it can't be a download problem.
In my old Poser 8 runtime I have a lot of clothing for Alyson 1, including all of P6 Jessi's wardrobe converted for her (I believe that came with a content update for Poser 8).
I think Alyson 2 is almost entirely dependent on hand-me-downs, the poor girl.
I do have PhilC's basic clothing and obj2cr2 so I could knock out a simple freebie for Alyson2 fairly quickly if needed. Let me know if the onesie doesn't work for you.
Poser 11 Pro, Windows 10
toastie ( ) posted Tue, 14 May 2013 at 12:36 PM
Quote - I just checked my runtimes too - Alyson2 has very little bundled clothing specifically for her. I found just just the bra and panties. I bought physical copies of Poser until now, so it can't be a download problem.
Many thanks for the kind offer. I'll let you know if I get desperate for something :)
I was just amazed I couldn't find anything for the poor woman... there's usually always a freebie of some sort for just about any character. I thought I must be looking in the wrong places, but it seems like there's nothing much out there. All the freebies are actually for Anastasia!
NanetteTredoux ( ) posted Tue, 14 May 2013 at 12:51 PM
Before Anastasia, Alyson was the pariah of the Poser universe.
monkeycloud ( ) posted Tue, 14 May 2013 at 1:03 PM
Hmmm... whoops, sorry. Unfortunately it doesn't look like I've kept a version that hasn't been fed through Wardrobe Wizard in order to add the various morphs (including GNDA).
So looks like my onesie is a dud for your test, as is Toastie...sorry :(
I don't think I'll have time to redo the cr2 without morphs tonight, probably not this week... although I will in due course re-rig it, so I can play with it in the new Fitting Room... or as part of that.
EClark1894 ( ) posted Tue, 14 May 2013 at 1:43 PM
You do know, of course, that Anastasia is a morph of Alyson2, so if you use Wardrobe Wizard, you might be able to make Anastasia's clothes fit her.
toastie ( ) posted Tue, 14 May 2013 at 7:23 PM
Quote - You do know, of course, that Anastasia is a morph of Alyson2, so if you use Wardrobe Wizard, you might be able to make Anastasia's clothes fit her.
Yup. Thanks. But I'm not using WW for this.
toastie ( ) posted Tue, 14 May 2013 at 7:49 PM
Quote - Hmmm... whoops, sorry. Unfortunately it doesn't look like I've kept a version that hasn't been fed through Wardrobe Wizard in order to add the various morphs (including GNDA).
No worries. I think I might just ditch this idea anyway. Ana can just stick to wearing dynamic stuff :)
monkeycloud ( ) posted Wed, 15 May 2013 at 2:06 AM
Well, I made a start on preparing a new blank rigged version of the onesie last night... as I'll need that for my own experimentation with the Fitting Room, in due course ;)
Not got a lotta time just now... but I'll hopefully get it done for later in the week, or so...
monkeycloud ( ) posted Wed, 15 May 2013 at 2:15 AM
Obviously I had tried previously myself to put the Ana morphs into the onesie using Wardrobe Wizard.
I get great results with WW most of the time, but with the Ana morphs going into the onesie, I just wasn't really feeling satisfied with the result... I guess because I had spent time with the mesh in the modeller already, I was ultra aware of where the automated fit wasn't coming out as gracefully as if I manually fitted it...
...so I'd decided to go back and try manually fitting it to Ana, in Hexagon.
However, I'm now going to give the Fitting Room a try, once I get my hands on it... :)
EClark1894 ( ) posted Thu, 16 May 2013 at 3:05 PM
Actually, I think I may have some Alyson2 items, but I never released them. I'll check and if you want them, just say the word.
toastie ( ) posted Fri, 17 May 2013 at 6:42 AM
Quote - Actually, I think I may have some Alyson2 items, but I never released them. I'll check and if you want them, just say the word.
If you wouldn't mind - thanks! I only want to try out a conversion, so I'm not going to use any items for renders and will delete once I've done my tests.
I did try converting some simple clothing with WW and then converting to Ana, but the results weren't good. I think that's because my efforts with WW weren't good though. That's why I wanted to try something made for Alyson2 first.
EClark1894 ( ) posted Fri, 17 May 2013 at 1:46 PM
Wayback when I first started modeling, I made a little black dress for
Alyson 2.
I need to send this to you via email since I'm not posting it in the Freestuff forum.
Please send me a site mail with your email address.
toastie ( ) posted Fri, 17 May 2013 at 4:32 PM
Quote - Wayback when I first started modeling, I made a little black dress for
Alyson 2.
Sent - thanks!
