Sun, Feb 2, 1:58 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Subject: This renders only in pp2010?
luckybears ( ) posted Sat, 18 May 2013 at 2:32 PM · edited Sun, 02 February 2025 at 11:00 AM
I don't know any reason the model will not render in p8 or pp2010. It renders normally in pp2012.
There is nothing in particular in the model that know that might cause problems that I know off. There are a number of trancparencies and refections but no refraction on the water.
luckybears ( ) posted Sat, 18 May 2013 at 2:33 PM
after half an hour in p8/p2010 this what I see
hborre ( ) posted Sat, 18 May 2013 at 4:09 PM
Without seeing a general layout of the MATRoom and render settings, it is hard to assess why the app is stalling on the render.
seachnasaigh ( ) posted Sat, 18 May 2013 at 6:10 PM
If it's a PP2012 model, it may use material nodes which don't exist in P8/PP2010, such as SubSurfaceScatter.  Just one possibility.
markschum ( ) posted Sat, 18 May 2013 at 9:32 PM
I would check materials after loading the scene and look for missing nodes.
You can try using the hierarchy editor to hide most of the items in the scene and then make more visible if the renders work.
kalrua ( ) posted Sun, 19 May 2013 at 11:06 AM · edited Sun, 19 May 2013 at 11:09 AM
Oh.
It's bug (poser Hang).
Firefly/poser is awaiting a DLL used by another program (Outlook, VLC media player, AV, Chrome, flash, etc).
https://code.google.com/p/chromium/issues/detail?id=78254
 http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3560388&ebot_calc_page#message_3560388
Solution: Find program (use: procexp), kill process!
Sorry for my bad english.
WandW ( ) posted Sun, 19 May 2013 at 1:48 PM · edited Sun, 19 May 2013 at 1:49 PM
It could be a conflict with the Flash player Chome uses; Are you using the external library in PP 2012? That uses Air, not Flash.  However, I presume you can render other scenes in Poser 8/2010?
Eric Walters ( ) posted Sun, 19 May 2013 at 2:05 PM · edited Sun, 19 May 2013 at 2:06 PM
Hi Luckybears
I had this issue with P2010. Without IDL it would render-with IDL it would hang. I finally tracked it down to a particular texture using reflection (a bug). When I removed it-the render would complete. I do believe it was fixed in Poser2012
Eric
luckybears ( ) posted Mon, 20 May 2013 at 7:31 PM
Thanks for the replies I will check them all out :)
