Blender F.A.Q (Last Updated: 2025 Feb 16 5:25 pm)
http://cgcookie.com/blender/2011/07/11/tip-importing-brush-sets-with-an-add-on/
Perhaps the above tutorial can help with importing the brushes. I have never done this.
I just leave the interface as it is - if I changed it, it would confuse me when I watch tutorials.
Poser 11 Pro, Windows 10
To input the new theme start up Blender and then File User prefrences Theme tab and you will see the button to install Theme at the botton then find where you saved the theme XML file that you have. Then save user settings after the them file has been installed. I agree with Nanette if you are new to Blender and are learning from tutorial or such in the begining leaving the defualt theme is advisable. I have only changed my theme recently as I have become more comfortable with Blender. Aslo a note on theme make sure you have a verision of the theme that matches your current verision of Blender. Hope this helps
Lobo
Lobo3433
I use the Energy theme for blender it is much easier on my eyes the defualt theme can be a diffcult to focus on due to the similarities in the color scheme always had a bit of a issue with the defualt color scheme is not easy on the eyes
Lobo
Lobo3433
Your are very welcome glad I was able to help
Lobo3433
Lobo3433
I would like to put some brushes into blender,also I found a colourful layout I 'd like to use.The layout is in XML form the brushes are black and white jpg's mabe bump map looking.
Version 2.67 32 bit.
thanks
