Wed, Jan 22, 6:50 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 5:13 am)
Subject: EZSkin 2
Sheedee ( ) posted Wed, 05 June 2013 at 9:27 AM · edited Wed, 22 January 2025 at 6:50 AM
Hello;
Question:
Can EZSkin 2 also be used in PoserPro 2012?...
It says that its only for Poser 9 SR2.1+
And…if it is not for PoserPro 2012…is there a work around, so that it will work in the latest Poser versions?...
Thanks for viewing.
Nyghtfall ( ) posted Wed, 05 June 2013 at 9:41 AM
The + sign at the end of the product requirement means Poser 9 SR2.1 and above, so, yes, it also works with PP2012.
LaurieA ( ) posted Wed, 05 June 2013 at 9:50 AM
Works fine for me - PoserPro 2012 here. Knock yourself out ;).
hborre ( ) posted Wed, 05 June 2013 at 2:05 PM
Yep, works very well in PP2012 latest SR.
Sheedee ( ) posted Wed, 05 June 2013 at 5:48 PM
Is there a work around to this Poser build issue?...
sadly enaugh it seems that my Poser version wont allow me to play with EZSkin...
Nyghtfall ( ) posted Wed, 05 June 2013 at 6:17 PM
EZSkin is telling you you're using SR1.6.  You need to upgrade to SR3.1.
http://poser.smithmicro.com/pro2012-updates.html
Eric Walters ( ) posted Wed, 05 June 2013 at 11:27 PM
BTW: it works well with PoserPro2014 as well
LaurieA ( ) posted Thu, 06 June 2013 at 5:02 AM · edited Thu, 06 June 2013 at 5:03 AM
Yep, you need at least P9/PP12 SR 3.1 to play...
You should always apply all the Poser updates anyway since they fix bugs and things...
