Mon, Feb 3, 8:08 AM CST
Subject: modifying existing clothing prop
grahamastor ( ) posted Mon, 10 June 2013 at 4:26 PM · edited Mon, 03 February 2025 at 5:12 AM
Attached Link: http://www.renderosity.com/mod/bcs/saucy-for-sexy-top-ii/88123/
Hi all,
    I'm still learning and using Poser 2010. I'm interested in creating a set of images where a piece of clothing (existing purchased add-on) is rendered shorter and shorter - such as a skirt, or "Saucy for Sexy Top II" where it shortened or given a shredded texture. Could someone provide me a way of doing this, rather than purchasing more add-ons - "teach a man to fish" as it were.
Many thanks,
    Graham....
vilters ( ) posted Mon, 10 June 2013 at 4:41 PM
If you look closely at the content of that top, you will see that it uses a tranparancy map.
You could alter "paint" the transparancy map to make it render shorter and shorter and shorter.
markschum ( ) posted Tue, 11 June 2013 at 4:54 PM
yup , transparency map for shorter or  shredded clothing.
It is essentially a black/white image where black is transparent and white is visible. add an image map noode , load your  mask image to it, and connect to transparacy channel.
there should be tutorials.
