Wed, Nov 13, 9:09 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: Poser library really slow...
xpdev ( ) posted Tue, 11 June 2013 at 1:12 AM · edited Tue, 12 November 2024 at 2:20 PM
Some time ago I asked for help for poser library which resulted very slow adding link to a new content.
If I add a runtime (regardless of its size) library poser can be up to one minute before making it available.
Some time ago someone gers to manually edit the file "LibraryPrefs.xml" and delete references no longer use.
I must say I never had beneficial effects.
The only way back to Poser load fast in the library .....
is to reinstall Windows 7 ... but I was not always a good idea ...
It almost seems that poser store somewhere the library data that obviously with time become huge and slow down the library.
Does anyone have suggestions ?
Many thanks.
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
LaurieA ( ) posted Tue, 11 June 2013 at 1:27 AM
Update Adobe Flash and Air
xpdev ( ) posted Tue, 11 June 2013 at 1:30 AM · edited Tue, 11 June 2013 at 1:44 AM
I think they are update.....
Flash       11.7.700.202   -  ok
Adobe Air   2.7.1.19610
I need to update adob air, but i'm not able to find installation file for Windows 7 64bit....
xpdev ( ) posted Tue, 11 June 2013 at 1:57 AM
Ok, updated
Adobe air to release 3.7.0.1860
Flash to release 11.7.700.202
Always slow loading of new runtimes.
I just done a test by adding a little runtime  (50 mb)
It's been 38 seconde before Poser add new runtime to the library.
Updates flash and air are not the problem.
Any other ideas?
bagginsbill ( ) posted Tue, 11 June 2013 at 6:01 AM · edited Tue, 11 June 2013 at 6:02 AM
Open the display options. If you don't know where they are, you should read the manual.
Turn off re-open folders - it's the option that remembers every folder you ever opened and tries to re-open them at startup. I don't remember the exact name of this checkbox, and I'm out of town for a week so I can't check in Poser as I don't have it with me.
xpdev ( ) posted Tue, 11 June 2013 at 6:59 AM
thanks bagginsbill
but "Re-open folder" is unchecked....
the trouble is not "Re-open".
Thank the same, you are great.
ironsoul ( ) posted Wed, 12 June 2013 at 2:39 AM
Is contents indexing enabled on the runtime folder, I think someone suggested this as a solution in another post (right click over folder and select advance)
xpdev ( ) posted Wed, 12 June 2013 at 5:08 AM
Thanks, but i don't understand, sorry....
i need to check or uncheck the "indexing" ?
thanks.
estherau ( ) posted Wed, 12 June 2013 at 6:33 AM
I think I had this problem once and I not only deleted poser but I deleted all the preferences which I found in my application support folder (I'm on a mac) and that fixed my problem.
well I mostly use the advanced library manager by semidieu from runtimedna anyway, but i still wanted everything to work properly as it should.
MY ONLINE COMIC IS NOW LIVE
ironsoul ( ) posted Thu, 13 June 2013 at 2:46 AM
xpdev - looking at your post again I think the indexing idea is probably not worth trying and can cause more problems than it solves.
Do you have a very large library which possibly Poser is trying to rescan for some reason?
hborre ( ) posted Thu, 13 June 2013 at 10:56 AM
May be the disk needs to be defragged.
mackis3D ( ) posted Thu, 13 June 2013 at 2:24 PM · edited Thu, 13 June 2013 at 2:26 PM
xpdev has Windows 7 - no need to defrag the disk. Windows 7 does it in the background if needed. It should only be defragmented if someone wants to change the size of the partition.
The many problems users have with the library is not a Windows/ Mac problem, not a Antivirus problem, not a Firewall problem. The library is the problem.
