Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Go to the image map node and where it says u scale and v scale, take it down to something like 0.25 for each to start if it's a seamless image. Uncheck autofit. Turn your image quality to crisp.
If it's still bigger than what you want, you can keep turning the scale down to 0.15, 0.10, 0.005, etc.
You can tile a texture map over a surface in Poser by adjusting the values of the U_Scale and V_Scale in an Image_Map (see image above), but the result will only show in the rendered image, not in preview. Alternatively you can edit the UV map of the obj file itself. English Bob has a tutorial on "Tiling Texture Maps in Poser" which explains one way to tile the UV map of an obj.
Nobody noticed the OP material has the image scale set to 0?
I was wondering if someone could tell me how to resize a mat so that the pattern fits a dress Im working with.
Attached you will see my problem
Thanks
Steel
