Sun, Oct 6, 9:23 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Subject: ReSizing Mats
Steeleyes101 ( ) posted Sat, 22 June 2013 at 5:37 AM · edited Tue, 01 October 2024 at 9:03 PM
Hello all and hope your weekend is off to a great start.
I was wondering if someone could tell me how to resize a mat so that the pattern fits a dress Im working with.
Attached you will see my problem
Thanks
Steel
LaurieA ( ) posted Sat, 22 June 2013 at 6:32 AM · edited Sat, 22 June 2013 at 6:33 AM
Go to the image map node and where it says u scale and v scale, take it down to something like 0.25 for each to start if it's a seamless image. Uncheck autofit. Turn your image quality to crisp.
If it's still bigger than what you want, you can keep turning the scale down to 0.15, 0.10, 0.005, etc.
hborre ( ) posted Sat, 22 June 2013 at 6:40 AM
Otherwise, you would need to take both UVMapping and texture into a 3rd party, 2D paint program and resize the image to exactly fit the mesh.
Steeleyes101 ( ) posted Sat, 22 June 2013 at 6:50 AM
Thanks LaurieA  trying now
lesbentley ( ) posted Sat, 22 June 2013 at 7:02 AM · edited Sat, 22 June 2013 at 7:05 AM
Resizing the image file itself will not help. You could tile the image file in a paint app by combining a number of instances of the one image into a grid pattern.
You can tile a texture map over a surface in Poser by adjusting the values of the U_Scale and V_Scale in an Image_Map (see image above), but the result will only show in the rendered image, not in preview. Alternatively you can edit the UV map of the obj file itself. English Bob has a tutorial on "Tiling Texture Maps in Poser" which explains one way to tile the UV map of an obj.
hborre ( ) posted Sat, 22 June 2013 at 7:24 AM
The described method does work very well, however, you will need to embed the new object file into the cr2 if the model is a figure.  Strongly recommend working with copies only just in case something goes wrong.
bagginsbill ( ) posted Sat, 22 June 2013 at 8:47 AM
Nobody noticed the OP material has the image scale set to 0?
LaurieA ( ) posted Sat, 22 June 2013 at 8:49 AM
LOL I noticed but figured with what I told 'em that it would get fixed. :P
