Tue, Jan 21, 7:58 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 4:30 pm)
Subject: multiple UV maps from head object
ghostship2 ( ) posted Sat, 22 June 2013 at 6:10 PM · edited Tue, 21 January 2025 at 10:52 AM
I need to make a higher res template UV maps for V3 but don't see an option at export to exclude the lashes and mouth parts. Will the Pro version of UV mapper do this? Is there some secret way of excluding these body parts in the exported mesh?
ironsoul ( ) posted Sat, 22 June 2013 at 6:35 PM · edited Sat, 22 June 2013 at 6:39 PM
These are material zones not body parts, the only way I know of exporting material zones from Poser is to use Zbrush and Goz but I would be surprised if no one has developed a script to do this (although I've not found such a script).
ironsoul ( ) posted Sat, 22 June 2013 at 6:46 PM
One thought is could you use the group tool to create a prop from the skinface material and then export the prop to get the UVs?
Teyon ( ) posted Sat, 22 June 2013 at 6:52 PM · edited Sat, 22 June 2013 at 6:53 PM
Or you could just export out the head with the lashes, load it into UVMapper, select the lashes and delete them or move them out of the main UV space.  Easy Breezy.
ghostship2 ( ) posted Sat, 22 June 2013 at 7:25 PM
that worked well. Thanks guys!
