Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 9:10 pm)
Try using scenefixer on the cr2 to fix the FBM links?
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
I was morphing one just this afternoon and haven't had any problems....
"Oh - the manual says that? I have never read the manual - this must be why."I'm having a problem with FBM's also on V4.2 standard. I load the morph and it shows at the body level but there are no morphs loading to the individual body parts, the dial does nothing. This is happening both PP12 and pp14. I have done this a million times in the past with no problem at all, now they dont load. Strange.
Y'all have a great day.
Just a thought; did you happen to update V4 using DAZ Install Manager? It doesn't seem to reinitialize V4; I have to do it manually...
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Anyone else having this problem? Full body morphs are not working in V4WM and the other morphs seems to only work on a single body part. For example the Inhale morph only works on the chest and not on the abdomen. That means you have very limited function because if you crank up the Inhale on the chest you get a separate line on the addomen. The same thing happens with muscle morphs. You try to add abdomenal muscles and beyond a minumal adjustment it causes separate lines in the chest and hip. With regular V4.2 I load the morphs and do the setup from the body, but that does not work on V4WM. I've gone back to V4.2 because of all the hassle with the weight-mapped figure.
