Wed, Nov 13, 9:09 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: Shadows problems....
xpdev ( ) posted Tue, 16 July 2013 at 7:32 AM · edited Tue, 12 November 2024 at 2:01 PM
I was doing some tests to illuminate a room, and I have seen this problem with shadows
The only light in the sun (150%)
Sky outside is a dome but not visible in raytracing and no light emitter.
I checked all the materials in the room, but I did not find anything strange.
Do you recommend?
Thank you.
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
xpdev ( ) posted Tue, 16 July 2013 at 7:33 AM
the shadows problem closely
Render settings
Sun light settings
ironsoul ( ) posted Tue, 16 July 2013 at 12:09 PM
Try increasing the indirect light quality.
ErickL88 ( ) posted Tue, 16 July 2013 at 12:40 PM
IIRC, by switching off Irradiance Cache (for IDL), you can avoid these splotches. But it tremendously will increase render times.
I haven't read anything that this got better with PP2014 tho.
xpdev ( ) posted Tue, 16 July 2013 at 12:40 PM
Done, the same shadow problem.
primorge ( ) posted Tue, 16 July 2013 at 1:53 PM
Yeah, BB suggested switching off IC to eliminate those artifacts... See this thread.
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=4061429&ebot_calc_page#message_4061429
xpdev ( ) posted Tue, 16 July 2013 at 2:34 PM
i have made this test this mornig primorge, but render time is very very very long....
and the room is empty....
hborre ( ) posted Tue, 16 July 2013 at 3:17 PM
Your pixel sampling seems rather high.
luckybears ( ) posted Tue, 16 July 2013 at 3:51 PM · edited Tue, 16 July 2013 at 4:05 PM
Similarity of colour of seperate objects that touch can contribute to this problem. Try making the colour idfference greater eg the wooded spars darker
Yje image is lit by tqo panels with an ambient value of 10.
The artifact is not evident o the red cube but it does show a little on the plane it's resting on, not so much as with the cube that is the same colour as the floor though
xpdev ( ) posted Wed, 17 July 2013 at 2:13 AM
Better ???
hborre ( ) posted Wed, 17 July 2013 at 10:49 AM
You can still see them at the far wall where it meets the floor.  But better.
primorge ( ) posted Wed, 17 July 2013 at 11:00 AM
Does look better... hborre is right also about your pixel samples. I'd say samples of 8 is the highest range for quality that I would go, many would think that 8 is too high. That's definitely contributing to the render time.
