Mon, Jan 13, 4:16 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: losing morphs when reopening scene
michelvanspeybroeck ( ) posted Tue, 16 July 2013 at 3:39 PM · edited Mon, 13 January 2025 at 4:01 AM
I often lose the possibility to morph hair, faces, whatever when i save and close a scene. This occurs when i save the scene shut down my computer and restart it the next day to work on the same scene. Kind of frustrating. I use poser pro 2012.
Any sollutions available?
Thanks.
Michel
xpdev ( ) posted Tue, 16 July 2013 at 4:33 PM · edited Tue, 16 July 2013 at 4:36 PM
re-install poser from original files
 first try to save scene without pmd file
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
ghostship2 ( ) posted Tue, 16 July 2013 at 4:53 PM
in general prefs (edit menue, gen preff's, misc tab) there is an option for using external binary morph targets...uncheck this and see what happens. I have had the same problem and this should fix it for you.
michelvanspeybroeck ( ) posted Tue, 16 July 2013 at 5:14 PM
Tnank you hav unchecked use external.... hope it works.
TrekkieGrrrl ( ) posted Tue, 16 July 2013 at 6:41 PM
I had this happen some days ago.. Without apparent reason. ONE scene out of several loaded without the morphs. Luckily I had an almost identical scene saved that worked,
The pmd's were present at the same place at the scene. I haven't turned them off.. (they're handy if you actually want to share morphs)
But I suspect a minor bug somewhere. Mine was PP2014 btw. not 2012.
hborre ( ) posted Tue, 16 July 2013 at 7:45 PM
PMD's have been known to become corrupted for no apparent reason.  However, SM has gone through great pain to correct much of the problems with the current Poser version.
Eric Walters ( ) posted Tue, 16 July 2013 at 8:25 PM
Hi
How can they be used to share morphs?
Thanks
Quote - I had this happen some days ago.. Without apparent reason. ONE scene out of several loaded without the morphs. Luckily I had an almost identical scene saved that worked,
TrekkieGrrrl ( ) posted Wed, 17 July 2013 at 7:01 AM
I've used them as morph injectors for the native Poser figures. It's easy beause the morphs are aleady in their own file when you use pmd's :)
You can see it used in for instance in the Five Free Faces for Simon
(click to download)
